i want to bring up camera function on thor,my serders is max9295+max96712, on max96712, the serders video pipe is lock,but on thor, i cat get the data by "
v4l2-ctl -d /dev/video1 --set-ctrl bypass_mode=0 --stream-mmap
I don’t fully understand this part, what’s your pipeline for fetching the sensor streaming?
besides, it looks you have four 4-lane camera on CSI-C, you may also check To verify the port binding result.
What do the statuses in the trace log mean? Is the VC accurate? I set the VC of the video stream to 1, but the VC in the trace log is 0—what is the reason for this?
it usually due to DPHY deskew calibration not complete, it happened when the calibration sequence length is not long enough.
please give it a try to configure cil_settletime, you may also review the pixel clock rate settings.
Thank you. I have tried modifying cil_settletime to 40/50/60 and adjusting pix_clk_hz, but it still didn’t work—the error in the trace log remains the same. Do you have any other suggestions?
it’s camera firmware waits for deskew calibration done when data-rate > 1.5 Gbps.
could you please refer to Sensor Pixel Clock section, let’s double check your clock rate settings, which must be set correctly to avoid potential issues.
Thank you. The data rate I am using is 1.5G per lane, which does not exceed 1.5G. Why is the error “DPHY deskew calibration not complete” reported? The Sensor Pixel Clock is filled in according to the instructions.
Thank you very much. We used the method you provided to enable the trace log, and after our investigation, we found that the issue was caused by poor MIPI signal quality.
