使用v4l2拉流时出现mipi一直重启log如下:
v4l2-ctl --device /dev/video0 --stream-mmap --stream-count=1 --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_REQBUFS returned 0 (Success)
VIDIOC_QUERYBUF returned 0 (Success)
VIDIOC_G_FMT returned 0 (Success)
VIDIOC_QBUF returned 0 (Success)
VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq: 1 bytesused: 4608000 ts: 0.000000 field: None (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 0 bytesused: 4608000 ts: 0.000000 field: None (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 2 bytesused: 4608000 ts: 0.000000 field: None (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 3 bytesused: 4608000 ts: 0.000000 field: None (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 4 bytesused: 4608000 ts: 0.000000 field: None (error, ts-monotonic, ts-src-eof)
dmesg log:
[ 644.282321] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 644.282350] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 644.287522] tegra194-vi5 8181200000.host1x:vi0@8188400000: vi5_get_syncpt_gos_backing: id=110 addr=0x7ffc6e0000 gos_idx=255 gos_offset=0
[ 644.287531] tegra194-vi5 8181200000.host1x:vi0@8188400000: vi5_get_syncpt_gos_backing: id=111 addr=0x7ffc6f0000 gos_idx=255 gos_offset=0
[ 644.287536] tegra194-vi5 8181200000.host1x:vi0@8188400000: vi5_get_syncpt_gos_backing: id=112 addr=0x7ffc700000 gos_idx=255 gos_offset=0
[ 644.287851] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 644.330287] [RCE] VI ch[35] frame configuration: 1920x1200
[ 644.330296] [RCE] left skip pixels=0 top skip lines=0
[ 644.330299] [RCE] right crop pixels=1920 bottom crop lines=1200
[ 644.330302] [RCE] pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196
[ 646.842313] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 646.842347] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 646.847536] tegra194-vi5 8181200000.host1x:vi0@8188400000: vi5_get_syncpt_gos_backing: id=110 addr=0x7ffc6e0000 gos_idx=255 gos_offset=0
[ 646.847545] tegra194-vi5 8181200000.host1x:vi0@8188400000: vi5_get_syncpt_gos_backing: id=111 addr=0x7ffc6f0000 gos_idx=255 gos_offset=0
[ 646.847550] tegra194-vi5 8181200000.host1x:vi0@8188400000: vi5_get_syncpt_gos_backing: id=112 addr=0x7ffc700000 gos_idx=255 gos_offset=0
[ 646.847862] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 646.850287] [RCE] VI ch[35] frame configuration: 1920x1200
[ 646.855621] [RCE] left skip pixels=0 top skip lines=0
[ 646.855625] [RCE] right crop pixels=1920 bottom crop lines=1200
[ 646.855630] [RCE] pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196
trace log:
cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 269/269 #P:14
_-----=> irqs-off/BH-disabled
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / _-=> migrate-disable
|||| / delay
TASK-PID CPU# ||||| TIMESTAMP FUNCTION
kworker/1:5-305 [001] ..... 641.754434: rtcpu_unknown: tstamp:664906214154 id:0x000d0000 len:36 data:6a 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] ..... 641.754436: rtcpu_unknown: tstamp:664908041460 id:0x000d0001 len:16 data:6a 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] ..... 641.754436: rtcpu_unknown: tstamp:664908915525 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] ..... 641.754438: rtcpu_unknown: tstamp:664908937349 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] ..... 641.754439: rtcpu_string: tstamp:664908959154 id:0x04010000 str:"VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 641.754449: rtcpu_string: tstamp:664908973173 id:0x04010000 str:" left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 641.754452: rtcpu_string: tstamp:664908988497 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 641.754453: rtcpu_string: tstamp:664909003812 id:0x04010000 str:“00
kworker/1:5-305 [001] … 641.754456: rtcpu_string: tstamp:664909018062 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 641.754456: rtcpu_string: tstamp:664909032154 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754459: rtcpu_unknown: tstamp:664909128997 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 641.754460: rtcpu_unknown: tstamp:664909150701 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 641.754462: rtcpu_vinotify_event: tstamp:664909197654 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:664909074256 data:0xbf40d50010000000
kworker/1:5-305 [001] … 641.754462: rtcpu_vinotify_event: tstamp:664909284840 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:664909081840 data:0x0000000031000001
kworker/1:5-305 [001] … 641.754463: rtcpu_unknown: tstamp:664909256154 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 641.754464: rtcpu_unknown: tstamp:664909276404 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 641.754464: rtcpu_vinotify_event: tstamp:664909303654 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:664909101836 data:0x0000000007020001
kworker/1:5-305 [001] … 641.754464: rtcpu_vinotify_event: tstamp:664909311266 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:664909198188 data:0xbf40d20010000000
kworker/1:5-305 [001] … 641.754465: rtcpu_unknown: tstamp:664909334265 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 641.754465: rtcpu_unknown: tstamp:664909819238 id:0x000f0004 len:40 data:00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 00 ec 67 0b 00 02 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 641.754465: rtcpu_string: tstamp:664909835321 id:0x04010000 str:"===== NVCSI Stream Configuration =====
kworker/1:5-305 [001] … 641.754468: rtcpu_string: tstamp:664909848877 id:0x04010000 str:"stream_id: PP 0, csi_port: PORT A
kworker/1:5-305 [001] … 641.754470: rtcpu_string: tstamp:664909861904 id:0x04010000 str:"Brick: PHY 0, Mode: D-PHY
kworker/1:5-305 [001] … 641.754472: rtcpu_string: tstamp:664909876914 id:0x04010000 str:"Partition: CIL A, LP bypass: Enabled, Lanes: 2
kworker/1:5-305 [001] … 641.754475: rtcpu_string: tstamp:664909886969 id:0x04010000 str:"Clock information:
kworker/1:5-305 [001] … 641.754478: rtcpu_string: tstamp:664909898525 id:0x04010000 str:"CIL rate: 270000000 Hz
kworker/1:5-305 [001] … 641.754480: rtcpu_string: tstamp:664909911099 id:0x04010000 str:"MIPI clock rate: 747500 kHz
kworker/1:5-305 [001] … 641.754482: rtcpu_string: tstamp:664909923099 id:0x04010000 str:“Physical rate: 1495000 Kbps
kworker/1:5-305 [001] … 641.754484: rtcpu_string: tstamp:664909932478 id:0x04010000 str:“T_HS settle: "
kworker/1:5-305 [001] … 641.754485: rtcpu_string: tstamp:664909941840 id:0x04010000 str:“autoconfigured”
kworker/1:5-305 [001] … 641.754485: rtcpu_string: tstamp:664909951247 id:0x04010000 str:”, T_CLK settle: "
kworker/1:5-305 [001] … 641.754486: rtcpu_string: tstamp:664909960766 id:0x04010000 str:“autoconfigured”
kworker/1:5-305 [001] … 641.754486: rtcpu_string: tstamp:664909972914 id:0x04010000 str:”
kworker/1:5-305 [001] … 641.754489: rtcpu_unknown: tstamp:664909981664 id:0x000f0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 641.754489: rtcpu_unknown: tstamp:664910059617 id:0x000f0000 len:16 data:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 641.754490: rtcpu_string: tstamp:664910093803 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c1c m”
kworker/1:5-305 [001] … 641.754490: rtcpu_string: tstamp:664910117978 id:0x04010000 str:“ask=0x06000000 value=0x04000000 (was 0x04020100”
kworker/1:5-305 [001] … 641.754491: rtcpu_string: tstamp:664910124423 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754494: rtcpu_string: tstamp:664910158904 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c1c m”
kworker/1:5-305 [001] … 641.754495: rtcpu_string: tstamp:664910182877 id:0x04010000 str:“ask=0x06070000 value=0x00020000 (was 0x04020100”
kworker/1:5-305 [001] … 641.754495: rtcpu_string: tstamp:664910189756 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754497: rtcpu_string: tstamp:664910215988 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c58 m”
kworker/1:5-305 [001] … 641.754498: rtcpu_string: tstamp:664910239340 id:0x04010000 str:“ask=0x000f0000 value=0x000f0000 (was 0x000f0002”
kworker/1:5-305 [001] … 641.754498: rtcpu_string: tstamp:664910245719 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754502: rtcpu_string: tstamp:664910272145 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c68 m”
kworker/1:5-305 [001] … 641.754502: rtcpu_string: tstamp:664910295886 id:0x04010000 str:“ask=0xffffffff value=0x84208420 (was 0x84e98ce5”
kworker/1:5-305 [001] … 641.754502: rtcpu_string: tstamp:664910302228 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754505: rtcpu_string: tstamp:664910329210 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c6c m”
kworker/1:5-305 [001] … 641.754505: rtcpu_string: tstamp:664910352941 id:0x04010000 str:“ask=0xffffffff value=0x84208420 (was 0xd41b9c25”
kworker/1:5-305 [001] … 641.754506: rtcpu_string: tstamp:664910359377 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754509: rtcpu_string: tstamp:664910385145 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c90 m”
kworker/1:5-305 [001] … 641.754509: rtcpu_string: tstamp:664910408673 id:0x04010000 str:“ask=0x0000f0fc value=0x00002040 (was 0x00000055”
kworker/1:5-305 [001] … 641.754510: rtcpu_string: tstamp:664910415127 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754512: rtcpu_string: tstamp:664910441821 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011c94 m”
kworker/1:5-305 [001] … 641.754513: rtcpu_string: tstamp:664910465349 id:0x04010000 str:“ask=0x000000ff value=0x00000011 (was 0x00070000”
kworker/1:5-305 [001] … 641.754513: rtcpu_string: tstamp:664910471775 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754516: rtcpu_string: tstamp:664910498154 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011cb4 m”
kworker/1:5-305 [001] … 641.754516: rtcpu_string: tstamp:664910521941 id:0x04010000 str:“ask=0x007f7f7f value=0x00404444 (was 0x00000000”
kworker/1:5-305 [001] … 641.754519: rtcpu_string: tstamp:664910528386 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754522: rtcpu_string: tstamp:664910554090 id:0x04010000 str:“NVCSI prod write phy: 0 cil: 0 reg=0x00011cec m”
kworker/1:5-305 [001] … 641.754522: rtcpu_string: tstamp:664910577571 id:0x04010000 str:“ask=0x000000ff value=0x00000027 (was 0x00007411”
kworker/1:5-305 [001] … 641.754523: rtcpu_string: tstamp:664910583988 id:0x04010000 str:"
kworker/1:5-305 [001] … 641.754525: rtcpu_unknown: tstamp:664910632136 id:0x000a000a len:16 data:00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 641.754526: rtcpu_unknown: tstamp:664910645543 id:0x000a000f len:20 data:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 641.754526: rtcpu_unknown: tstamp:664911784932 id:0x000a0010 len:12 data:00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 641.754527: rtcpu_unknown: tstamp:664911797914 id:0x000a000c len:4 data:00 00 00 00
kworker/1:5-305 [001] … 641.754527: rtcpu_unknown: tstamp:664911838228 id:0x000a0009 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 30 00 00 00 22 00 00 00
kworker/1:5-305 [001] … 641.754528: rtcpu_string: tstamp:664911856803 id:0x04010000 str:“CSI port AB IDAC calibration result with freqba”
kworker/1:5-305 [001] … 641.754528: rtcpu_string: tstamp:664911872543 id:0x04010000 str:“nd=0:
kworker/1:5-305 [001] … 641.754530: rtcpu_string: tstamp:664911886914 id:0x04010000 str:” Trio A0 rxab=20 rxbc=19 rxca=16
kworker/1:5-305 [001] … 641.754533: rtcpu_string: tstamp:664911900941 id:0x04010000 str:" Trio A1 rxab=15 rxbc=19 rxca=13
kworker/1:5-305 [001] … 641.754535: rtcpu_string: tstamp:664911917136 id:0x04010000 str:“CSI port AB IDAC calibration result with freqba”
kworker/1:5-305 [001] … 641.754535: rtcpu_string: tstamp:664911932895 id:0x04010000 str:“nd=0:
kworker/1:5-305 [001] … 641.754538: rtcpu_string: tstamp:664911946951 id:0x04010000 str:” Trio B0 rxab=19 rxbc=15 rxca=20
kworker/1:5-305 [001] … 641.754540: rtcpu_string: tstamp:664911960923 id:0x04010000 str:" Trio B1 rxab=14 rxbc=19 rxca=27
kworker/1:5-305 [001] … 641.754542: rtcpu_unknown: tstamp:664911971228 id:0x000a0006 len:28 data:00 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00
kworker/1:5-305 [001] … 641.754543: rtcpu_string: tstamp:664911981312 id:0x04010000 str:“CSI port AB
kworker/1:5-305 [001] … 641.754545: rtcpu_string: tstamp:664911992219 id:0x04010000 str:” AFE_HFGAIN_IO0_A=7
kworker/1:5-305 [001] … 641.754547: rtcpu_string: tstamp:664912003201 id:0x04010000 str:" AFE_HFGAIN_IO1_A=7
kworker/1:5-305 [001] … 641.754549: rtcpu_string: tstamp:664912014034 id:0x04010000 str:" AFE_HFGAIN_CLK_A=7
kworker/1:5-305 [001] … 641.754551: rtcpu_string: tstamp:664912024904 id:0x04010000 str:" AFE_HFGAIN_IO0_B=7
kworker/1:5-305 [001] … 641.754554: rtcpu_string: tstamp:664912035923 id:0x04010000 str:" AFE_HFGAIN_IO1_B=7
kworker/1:5-305 [001] … 641.754556: rtcpu_string: tstamp:664912046895 id:0x04010000 str:" AFE_HFGAIN_CLK_B=7
kworker/1:5-305 [001] … 641.754558: rtcpu_unknown: tstamp:664912053599 id:0x000a000b len:4 data:00 00 00 00
kworker/1:5-305 [001] … 641.754559: rtcpu_unknown: tstamp:664912068229 id:0x000f0001 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 641.754559: rtcpu_vinotify_event: tstamp:664919174979 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:664909227105 data:0x0000000031000002
kworker/1:5-305 [001] … 644.330280: rtcpu_unknown: tstamp:667494330064 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 644.330282: rtcpu_unknown: tstamp:667494793425 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 644.330283: rtcpu_unknown: tstamp:667495328277 id:0x000d0000 len:36 data:6b 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 644.330283: rtcpu_unknown: tstamp:667495354175 id:0x000d0001 len:16 data:6b 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 644.330284: rtcpu_unknown: tstamp:667495633110 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 644.330284: rtcpu_unknown: tstamp:667495655018 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 644.330286: rtcpu_string: tstamp:667495677360 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 644.330296: rtcpu_string: tstamp:667495691407 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 644.330299: rtcpu_string: tstamp:667495707120 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 644.330299: rtcpu_string: tstamp:667495722481 id:0x04010000 str:“00
kworker/1:5-305 [001] … 644.330302: rtcpu_string: tstamp:667495736805 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 644.330302: rtcpu_string: tstamp:667495750971 id:0x04010000 str:"
kworker/1:5-305 [001] … 644.330305: rtcpu_unknown: tstamp:667495872092 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 644.330306: rtcpu_unknown: tstamp:667495894110 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 644.330307: rtcpu_vinotify_event: tstamp:667495941499 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:667495793536 data:0xbf40d50010000000
kworker/1:5-305 [001] … 644.330308: rtcpu_vinotify_event: tstamp:667495950194 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:667495821376 data:0x0000000031000001
kworker/1:5-305 [001] … 644.330309: rtcpu_unknown: tstamp:667496004342 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 644.330309: rtcpu_unknown: tstamp:667496026194 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 644.330310: rtcpu_vinotify_event: tstamp:667496037944 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:667495827392 data:0x0000000007020001
kworker/1:5-305 [001] … 644.330310: rtcpu_vinotify_event: tstamp:667496056842 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:667495942741 data:0xbf40d20010000000
kworker/1:5-305 [001] … 644.330311: rtcpu_vinotify_event: tstamp:667496064333 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:667495950421 data:0x0000000031000002
kworker/1:5-305 [001] … 644.330311: rtcpu_unknown: tstamp:667496087536 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 646.850281: rtcpu_unknown: tstamp:670054316650 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 646.850283: rtcpu_unknown: tstamp:670054793317 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 646.850283: rtcpu_unknown: tstamp:670055340854 id:0x000d0000 len:36 data:6c 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 646.850284: rtcpu_unknown: tstamp:670055366910 id:0x000d0001 len:16 data:6c 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 646.850284: rtcpu_unknown: tstamp:670055644548 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 646.850285: rtcpu_unknown: tstamp:670055666493 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 646.850287: rtcpu_string: tstamp:670055688873 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 646.855621: rtcpu_string: tstamp:670055702993 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 646.855625: rtcpu_string: tstamp:670055718410 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 646.855626: rtcpu_string: tstamp:670055733761 id:0x04010000 str:“00
kworker/1:5-305 [001] … 646.855629: rtcpu_string: tstamp:670055748076 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 646.855630: rtcpu_string: tstamp:670055762243 id:0x04010000 str:"
kworker/1:5-305 [001] … 646.855633: rtcpu_unknown: tstamp:670055857280 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 646.855635: rtcpu_unknown: tstamp:670055879197 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 646.855636: rtcpu_vinotify_event: tstamp:670055926872 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:670055804024 data:0xbf40d50010000000
kworker/1:5-305 [001] … 646.855637: rtcpu_unknown: tstamp:670055982947 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 646.855637: rtcpu_unknown: tstamp:670056004576 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 646.855638: rtcpu_vinotify_event: tstamp:670056015789 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:670055811672 data:0x0000000031000001
kworker/1:5-305 [001] … 646.855638: rtcpu_vinotify_event: tstamp:670056034706 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:670055835979 data:0x0000000007020001
kworker/1:5-305 [001] … 646.855639: rtcpu_vinotify_event: tstamp:670056042123 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:670055927723 data:0xbf40d20010000000
kworker/1:5-305 [001] … 646.855639: rtcpu_unknown: tstamp:670056065048 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 646.910288: rtcpu_vinotify_event: tstamp:670065620428 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:670055956716 data:0x0000000031000002
kworker/1:5-305 [001] … 649.430124: rtcpu_unknown: tstamp:672614316296 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 649.430126: rtcpu_unknown: tstamp:672614793370 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 649.430126: rtcpu_unknown: tstamp:672615351499 id:0x000d0000 len:36 data:6d 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 649.430126: rtcpu_unknown: tstamp:672615377453 id:0x000d0001 len:16 data:6d 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 649.430127: rtcpu_unknown: tstamp:672615663703 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 649.430127: rtcpu_unknown: tstamp:672615685629 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 649.430129: rtcpu_string: tstamp:672615707805 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 649.430138: rtcpu_string: tstamp:672615721870 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 649.430141: rtcpu_string: tstamp:672615737286 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 649.430141: rtcpu_string: tstamp:672615752610 id:0x04010000 str:“00
kworker/1:5-305 [001] … 649.430144: rtcpu_string: tstamp:672615766907 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 649.430145: rtcpu_string: tstamp:672615782138 id:0x04010000 str:"
kworker/1:5-305 [001] … 649.430147: rtcpu_unknown: tstamp:672615900731 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 649.430148: rtcpu_unknown: tstamp:672615923722 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 649.430150: rtcpu_vinotify_event: tstamp:672615971314 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:672615821833 data:0xbf40d50010000000
kworker/1:5-305 [001] … 649.430150: rtcpu_vinotify_event: tstamp:672615979601 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:672615849609 data:0x0000000031000001
kworker/1:5-305 [001] … 649.430150: rtcpu_unknown: tstamp:672616036351 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 649.430151: rtcpu_unknown: tstamp:672616058157 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 649.430151: rtcpu_vinotify_event: tstamp:672616070101 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:672615855689 data:0x0000000007020001
kworker/1:5-305 [001] … 649.430152: rtcpu_vinotify_event: tstamp:672616088694 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:672615971009 data:0xbf40d20010000000
kworker/1:5-305 [001] … 649.430152: rtcpu_vinotify_event: tstamp:672616096444 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:672615978689 data:0x0000000031000002
kworker/1:5-305 [001] … 649.430152: rtcpu_unknown: tstamp:672616119027 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 652.006131: rtcpu_unknown: tstamp:675174318564 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 652.006132: rtcpu_unknown: tstamp:675174793295 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 652.006133: rtcpu_unknown: tstamp:675175358638 id:0x000d0000 len:36 data:6e 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 652.006133: rtcpu_unknown: tstamp:675175384610 id:0x000d0001 len:16 data:6e 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 652.006133: rtcpu_unknown: tstamp:675175658203 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 652.006134: rtcpu_unknown: tstamp:675175680490 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 652.006135: rtcpu_string: tstamp:675175702897 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 652.006145: rtcpu_string: tstamp:675175716990 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 652.006148: rtcpu_string: tstamp:675175732332 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 652.006148: rtcpu_string: tstamp:675175747647 id:0x04010000 str:“00
kworker/1:5-305 [001] … 652.006151: rtcpu_string: tstamp:675175761916 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 652.006151: rtcpu_string: tstamp:675175776017 id:0x04010000 str:"
kworker/1:5-305 [001] … 652.006153: rtcpu_unknown: tstamp:675175874388 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 652.006154: rtcpu_unknown: tstamp:675175896684 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 652.006155: rtcpu_vinotify_event: tstamp:675175944536 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:675175821294 data:0xbf40d50010000000
kworker/1:5-305 [001] … 652.006156: rtcpu_vinotify_event: tstamp:675176029647 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:675175828942 data:0x0000000031000001
kworker/1:5-305 [001] … 652.006156: rtcpu_unknown: tstamp:675176002184 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 652.006157: rtcpu_unknown: tstamp:675176022629 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 652.006157: rtcpu_vinotify_event: tstamp:675176048527 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:675175848866 data:0x0000000007020001
kworker/1:5-305 [001] … 652.006157: rtcpu_vinotify_event: tstamp:675176056434 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:675175949058 data:0xbf40d20010000000
kworker/1:5-305 [001] … 652.006158: rtcpu_unknown: tstamp:675176080249 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 652.006158: rtcpu_vinotify_event: tstamp:675186291128 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:675175976941 data:0x0000000031000002
kworker/1:5-305 [001] … 654.582292: rtcpu_unknown: tstamp:677734319666 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 654.582294: rtcpu_unknown: tstamp:677734793406 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 654.582295: rtcpu_unknown: tstamp:677735349582 id:0x000d0000 len:36 data:6f 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 654.582295: rtcpu_unknown: tstamp:677735375619 id:0x000d0001 len:16 data:6f 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 654.582296: rtcpu_unknown: tstamp:677735653184 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 654.582297: rtcpu_unknown: tstamp:677735675462 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 654.582299: rtcpu_string: tstamp:677735697842 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 654.582309: rtcpu_string: tstamp:677735711879 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 654.582312: rtcpu_string: tstamp:677735727258 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 654.582312: rtcpu_string: tstamp:677735742527 id:0x04010000 str:“00
kworker/1:5-305 [001] … 654.582315: rtcpu_string: tstamp:677735756814 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 654.582316: rtcpu_string: tstamp:677735770925 id:0x04010000 str:"
kworker/1:5-305 [001] … 654.582318: rtcpu_unknown: tstamp:677735892795 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 654.582319: rtcpu_unknown: tstamp:677735914629 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 654.582320: rtcpu_vinotify_event: tstamp:677735961823 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:677735812699 data:0xbf40d50010000000
kworker/1:5-305 [001] … 654.582321: rtcpu_vinotify_event: tstamp:677735970045 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:677735840475 data:0x0000000031000001
kworker/1:5-305 [001] … 654.582322: rtcpu_unknown: tstamp:677736023906 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 654.582323: rtcpu_unknown: tstamp:677736045592 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 654.582324: rtcpu_vinotify_event: tstamp:677736057879 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:677735846491 data:0x0000000007020001
kworker/1:5-305 [001] … 654.582324: rtcpu_vinotify_event: tstamp:677736076841 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:677735961836 data:0xbf40d20010000000
kworker/1:5-305 [001] … 654.582324: rtcpu_vinotify_event: tstamp:677736084323 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:677735969548 data:0x0000000031000002
kworker/1:5-305 [001] … 654.582325: rtcpu_unknown: tstamp:677736107601 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 657.102144: rtcpu_unknown: tstamp:680294301647 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 657.102145: rtcpu_unknown: tstamp:680294793332 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 657.102145: rtcpu_unknown: tstamp:680295346795 id:0x000d0000 len:36 data:70 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 657.102146: rtcpu_unknown: tstamp:680295372804 id:0x000d0001 len:16 data:70 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 657.102146: rtcpu_unknown: tstamp:680295652980 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 657.102147: rtcpu_unknown: tstamp:680295674943 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 657.102149: rtcpu_string: tstamp:680295697332 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 657.102159: rtcpu_string: tstamp:680295711452 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 657.102162: rtcpu_string: tstamp:680295726823 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 657.102163: rtcpu_string: tstamp:680295742156 id:0x04010000 str:“00
kworker/1:5-305 [001] … 657.102165: rtcpu_string: tstamp:680295756462 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 657.102166: rtcpu_string: tstamp:680295770601 id:0x04010000 str:"
kworker/1:5-305 [001] … 657.102168: rtcpu_unknown: tstamp:680295867425 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 657.102169: rtcpu_unknown: tstamp:680295889202 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 657.102171: rtcpu_vinotify_event: tstamp:680295936823 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:680295812603 data:0xbf40d50010000000
kworker/1:5-305 [001] … 657.102171: rtcpu_unknown: tstamp:680295989656 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 657.102172: rtcpu_unknown: tstamp:680296011295 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 657.102172: rtcpu_vinotify_event: tstamp:680296023295 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:680295820187 data:0x0000000031000001
kworker/1:5-305 [001] … 657.102173: rtcpu_vinotify_event: tstamp:680296042239 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:680295840184 data:0x0000000007020001
kworker/1:5-305 [001] … 657.102173: rtcpu_vinotify_event: tstamp:680296049693 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:680295936536 data:0xbf40d20010000000
kworker/1:5-305 [001] … 657.102174: rtcpu_unknown: tstamp:680296072888 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 657.102174: rtcpu_vinotify_event: tstamp:680305928387 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:680295964390 data:0x0000000031000002
kworker/1:5-305 [001] … 659.678130: rtcpu_unknown: tstamp:682854321531 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 659.678132: rtcpu_unknown: tstamp:682854793346 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 659.678132: rtcpu_unknown: tstamp:682855365318 id:0x000d0000 len:36 data:71 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 659.678132: rtcpu_unknown: tstamp:682855391356 id:0x000d0001 len:16 data:71 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 659.678133: rtcpu_unknown: tstamp:682855676402 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 659.678133: rtcpu_unknown: tstamp:682855698411 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 659.678135: rtcpu_string: tstamp:682855720198 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 659.678143: rtcpu_string: tstamp:682855734300 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 659.678146: rtcpu_string: tstamp:682855749735 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 659.678147: rtcpu_string: tstamp:682855765087 id:0x04010000 str:“00
kworker/1:5-305 [001] … 659.678150: rtcpu_string: tstamp:682855780143 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 659.678150: rtcpu_string: tstamp:682855794328 id:0x04010000 str:"
kworker/1:5-305 [001] … 659.678153: rtcpu_unknown: tstamp:682855913124 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 659.678153: rtcpu_unknown: tstamp:682855935152 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 659.678154: rtcpu_vinotify_event: tstamp:682855982448 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:682855833900 data:0xbf40d50010000000
kworker/1:5-305 [001] … 659.678155: rtcpu_vinotify_event: tstamp:682855990763 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:682855862540 data:0x0000000031000001
kworker/1:5-305 [001] … 659.678155: rtcpu_unknown: tstamp:682856048541 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 659.678156: rtcpu_unknown: tstamp:682856070596 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 659.678156: rtcpu_vinotify_event: tstamp:682856081994 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:682855868556 data:0x0000000007020001
kworker/1:5-305 [001] … 659.678156: rtcpu_vinotify_event: tstamp:682856100819 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:682855983679 data:0xbf40d20010000000
kworker/1:5-305 [001] … 659.678157: rtcpu_vinotify_event: tstamp:682856108207 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:682855991423 data:0x0000000031000002
kworker/1:5-305 [001] … 659.678157: rtcpu_unknown: tstamp:682856131235 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 662.254287: rtcpu_unknown: tstamp:685414307112 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 662.254289: rtcpu_unknown: tstamp:685414793334 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 662.254289: rtcpu_unknown: tstamp:685415347140 id:0x000d0000 len:36 data:72 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 662.254290: rtcpu_unknown: tstamp:685415373094 id:0x000d0001 len:16 data:72 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 662.254290: rtcpu_unknown: tstamp:685415654205 id:0x000d0006 len:24 data:00 00 00 00 00 00 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 04 00 00 00
kworker/1:5-305 [001] … 662.254291: rtcpu_unknown: tstamp:685415676066 id:0x000d0009 len:8 data:00 00 00 00 01 00 00 00
kworker/1:5-305 [001] … 662.254292: rtcpu_string: tstamp:685415698418 id:0x04010000 str:“VI ch[35] frame configuration: 1920x1200
kworker/1:5-305 [001] … 662.254303: rtcpu_string: tstamp:685415712455 id:0x04010000 str:” left skip pixels=0 top skip lines=0
kworker/1:5-305 [001] … 662.254306: rtcpu_string: tstamp:685415727769 id:0x04010000 str:" right crop pixels=1920 bottom crop lines=12"
kworker/1:5-305 [001] … 662.254306: rtcpu_string: tstamp:685415743418 id:0x04010000 str:“00
kworker/1:5-305 [001] … 662.254309: rtcpu_string: tstamp:685415757742 id:0x04010000 str:” pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196"
kworker/1:5-305 [001] … 662.254310: rtcpu_string: tstamp:685415771908 id:0x04010000 str:"
kworker/1:5-305 [001] … 662.254312: rtcpu_unknown: tstamp:685415867575 id:0x000d0006 len:24 data:00 00 00 00 01 00 00 00 01 00 00 00 6e 00 00 00 04 00 00 00 08 00 00 00
kworker/1:5-305 [001] … 662.254313: rtcpu_unknown: tstamp:685415889445 id:0x000d0009 len:8 data:00 00 00 00 02 00 00 00
kworker/1:5-305 [001] … 662.254315: rtcpu_vinotify_event: tstamp:685415936862 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:685415814535 data:0xbf40d50010000000
kworker/1:5-305 [001] … 662.254315: rtcpu_unknown: tstamp:685415994769 id:0x000d0006 len:24 data:00 00 00 00 02 00 00 00 02 00 00 00 6e 00 00 00 08 00 00 00 0c 00 00 00
kworker/1:5-305 [001] … 662.254316: rtcpu_unknown: tstamp:685416017223 id:0x000d0009 len:8 data:00 00 00 00 03 00 00 00
kworker/1:5-305 [001] … 662.254317: rtcpu_vinotify_event: tstamp:685416027695 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:685415822183 data:0x0000000031000001
kworker/1:5-305 [001] … 662.254317: rtcpu_vinotify_event: tstamp:685416046695 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:685415842139 data:0x0000000007020001
kworker/1:5-305 [001] … 662.254319: rtcpu_vinotify_event: tstamp:685416054223 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:685415938491 data:0xbf40d20010000000
kworker/1:5-305 [001] … 662.254319: rtcpu_unknown: tstamp:685416076492 id:0x000d0006 len:24 data:00 00 00 00 03 00 00 00 03 00 00 00 6e 00 00 00 0c 00 00 00 10 00 00 00
kworker/1:5-305 [001] … 662.254320: rtcpu_vinotify_event: tstamp:685425566057 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:685415966366 data:0x0000000031000002
kworker/1:5-305 [001] … 664.774139: rtcpu_unknown: tstamp:687974306655 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 664.774140: rtcpu_unknown: tstamp:687974793452 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 664.774141: rtcpu_unknown: tstamp:687975339970 id:0x000d0000 len:36 data:73 00 00 00 04 00 00 00 43 10 00 00 00 00 00 00 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 664.774141: rtcpu_unknown: tstamp:687975365980 id:0x000d0001 len:16 data:73 00 00 00 00 00 00 00 00 00 00 00 23 00 00 00
kworker/1:5-305 [001] … 664.886420: rtcpu_unknown: tstamp:688070212370 id:0x000d0004 len:4 data:00 00 00 00
kworker/1:5-305 [001] … 664.886425: rtcpu_unknown: tstamp:688070792972 id:0x000d0005 len:8 data:00 00 00 00 00 00 00 00
kworker/1:5-305 [001] … 669.938295: rtcpu_string: tstamp:693090081364 id:0x04010000 str:“VM0 deactivating.”
通过读取max96712的寄存器确定加解串的链路正常,并且通过示波器确认mipi有数据产生。
如下是节选dts配置:
以上log可以定位到问题原因吗?
