Can’t open usd file
when I save my file to the .Usd ;then reopen the file ,it can’t be open . And I try to open the file that demo’s .usd ,and it encounter same problem.
when i open the .usd file ,then terminal display that “/addr2line : DWARF error : section .debug is larger than its filesize” ,and then the isaac sim shutdown.
software specifications :
ubuntu :20.04
If there are any methods to deal with it,please let me know,thanks you.
Hi @benson.ee12 - The error message you’re seeing suggests that there might be an issue with the .usd file itself or with the way Isaac Sim is trying to open it. Here are a few troubleshooting steps you can try:
  1. Check the .usd file: Make sure the .usd file is not corrupted or incomplete. If you have a backup or a different version of the file, try opening that instead.
  2. Reinstall Isaac Sim: There might be an issue with your installation of Isaac Sim. Try uninstalling and then reinstalling the software.
  3. Update your system: Make sure your Ubuntu system and all its packages are up to date. You can do this by running the following commands in the terminal:
sudo apt update
sudo apt upgrade
  1. Check for software conflicts: There might be other software on your system that’s interfering with Isaac Sim. Try closing all other applications and then opening the .usd file in Isaac Sim.
