Load USD file for a long time
Isaac Sim Version
[V] 4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
[V] Windows 10
GPU Information
  • Model: RTX 3060
  • Driver Version:
Topic Description
Detailed Description
Take a long time (around 20 mins) to open an USD file in Isaac Sim ver 4.2.0
Steps to Reproduce
  1. Open an example in Window → Simulation → Demo Scenes → Rigid Bodies → Center of mass
  2. Add a sphere with Mesh type
  3. Save as another .usd file
  4. Open the USD file from step 3 → this took around 20 mins…
Error Messages
(In terminal)
[Warning] [omni.hydratexture.plugin] ‘/Render/OmniverseKit/HydraTextures/omni_kit_widget_viewport_ViewportTexture_0’ is not a Usd.RenderProduct and cannot be used, reseting to ‘/Render/OmniverseKit/HydraTextures/omni_kit_widget_viewport_ViewportTexture_0’
Screenshots or Videos
Additional Information
What I’ve Tried
  1. Re-install Isaac Sim/ Reboot PC
  2. Clear catch
  3. Load other USD file with few object (still take a long time around 10 mins…)
I could not replicate the issue on my end; it took about four seconds. Additionally, I noticed the warning, so I do not believe it is related to this.
Could you share your .usd file?
I can’t upload .usd file for the system restriction. So I share the link.
Here are two of .usd files. The snow man one is from example and add other objects, and the second one is created by myself. Both of them need to be loaded for around 10-20 mins.
From example and add other objects
Created by myself
Both items open in under 3 seconds.
Please check if the Windows issue in When using Isaac sim 4.2, opening USD, freezing, and getting stuck does not work properly is relevant.
