Isaac Sim version incompatibility
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
Operating System
Windows 11
Windows 10
Other (please specify):
GPU Information
  • Model: rtx 4070
  • Driver Version:
Topic Description
Detailed Description
Hi everyone! I have some usd models I created using Isaac Sim 2023.1.1 a couple of months ago. Currently I need to continue working with those models but apparently the new version of Isaac Sim has incompatibility with my files, they just crash when I try to upload them.
I have also tried to open the files just using open usd composer but still happens the same problem.
Anyone from NVIDIA that can let me know if there is any compatibility issues of .usd models between versions of Isaac Sim? Thank you
@delgad84 do you happen to have the crashlog reports/files you could attach?
The console error says: Failed wait for MDI material
Thank you for reaching out regarding the Isaac Sim version incompatibility issue. To assist you more effectively, we need additional information to replicate and diagnose the problem.
Could you please provide the complete log files, detailed steps, and any necessary files required to reproduce the issue?
Sure. The steps are just open the usd file in Isaac Sim from files. The cars models have materials, it should look methalic, not red. Here I included both files to be downloaded. Transfer "USD models" is available for download
I apologize for my late response. The transfer has expired. Could you please share it again?
Sure, there you are. Thank you for reaching out. Unique Download Link | WeTransfer
The USD files can be opened correctly on my end.
Are you running on Windows? Please check if the issue on Windows discussed in When using Isaac sim 4.2, opening USD, freezing, and getting stuck does not work properly is relevant.
