I can find any about that
10-bit H265 stream is supported. Please refer to the post:
Hdmi yuv422 - #10 by DaneLLL
I update the datasheet,and TX2NX shows that HEVC MAIN10
By the way, I see the datasheet of xavier nx shows that HEVC Main, Main 10, Main 12 Supports HEVC Main 12 (without monochrome) Supports Main 444 12 (without YUV422/YUV400). That means it can suport 12bit HEVC? I want to know which version of the jp can support it?
The software stacks support decoding 10-bit content although hardware decoder is capable of decoding 12-bit content. For the demonstration, please check the sample:
/usr/src/jetson_multimedia_api/samples/00_video_decode
