Can we connect external ADC/DAC(analog to digital & digital to analog converter) to ORIN AGX
I am trying to connect an external ADC/DAC (PCF8591 ADC/DAC) through pins shown in the “Jetson AGX Orin Developer Kit User Guide - Hardware | NVIDIA Developer
but the orin wouldn’t recognize or read the adc/dac while I’m using I2C buses for the connections.
I’m using the following connections:
Connecting the known I2C device to the Jetson Orin:
  • SDA pin to the SDA pin on the Jetson (e.g., Pin 3 - I2C5_DAT).
  • SCL pin to the SCL pin on the Jetson (e.g., Pin 5 - I2C5_CLK).
  • GND pin to a ground pin on the Jetson.
  • VCC pin to a suitable power source (3.3V or 5V depending on the device).
but the orin cant read the address when I’m connecting the following pins to the adc/dac module.
i need help with the connections and idk if the external adc/dac is compatible with the orin !!
i tried running various commands like:
i2cdetect - ran on all the available busses but couldn’t find the device address on any bus
can anyone please help me with this!
Maybe probe the i2c signal to confirm if device ack for the I2C broadcasting command.
thanks for the reply, i was just using wrong bus found the solution in some website that i2c pin 3 and 5 are connected to bus 7
the command tht i used is i2cdetect -y -a busnumber and found the adc register 48 on the bus 7
