Hi everyone,
I want to use I2C6 the Orin CVM Connector pins are J52 and J53. I added code in dts as below
pinmux@2430000 {
dp_aux_ch1_p_pn3 {
nvidia,pins = "dp_aux_ch1_p_pn3";
nvidia,function = "i2c4";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
dp_aux_ch1_n_pn4 {
nvidia,pins = "dp_aux_ch1_n_pn4";
nvidia,tristate = <TEGRA_PIN_DISABLE>;
Then I buid the dts and copy the dtb to develop board, I use command
i2cdetect -r -y 3
in terminal the J52 and J53 output nothing.
