I’m having trouble understanding whether or not the Tegra TX2’s CAN0_STBY pin will be available for use if I drop it into a Jetson TX1 carrier board.
The Jetson TX1-TX2 Developer Kit Carrier Board Specification ([url]http://developer.nvidia.com/embedded/dlc/jetson-tx1-tx2-developer-kit-carrier-board-spec[/url]) shows that pin3 of the J26 BPIO Expansion header is labeled with the “CAN0_STBY” signal name, yet is marked “Unused” and is greyed out. Also, the carrier board schematics in the Jetson TX1-TX2 Carrier Board Design Files (http://developer.nvidia.com/embedded/dlc/jetson-tx1-tx2-developer-kit-carrier-board-design-files) shows the same pin (J26-3) labeled as “CAN0_STBY”, and connected to pin E17 of the TX1/2.
Is the CAN0_STBY signal available if I drop a Tegra TX2 into a Jetson TX1 carrier board?
