Hello!
After installing Ubuntu on my laptop i tried to install a driver for my NVIDIA Geforce GT 740M. Sadly i wasn’t able to do so.
ubuntu:~$ lspci | grep "VGA\|3D"
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
0a:00.0 3D controller: NVIDIA Corporation GK208M [GeForce GT 740M] (rev a1)
I installed the version 319 of the driver in combination with bumblebee over apt-get.
Installed packages:
ubuntu:~$ dpkg --get-selections | grep -v deinstall | grep "bumblebee\|nvidia-\|bbswitch"
bbswitch-dkms install
bumblebee install
bumblebee-nvidia install
nvidia-319 install
nvidia-331 install
nvidia-340 install
nvidia-opencl-icd-340 install
nvidia-prime install
nvidia-settings install
If I use optirun to start a program i get this error:
[ 901.661718] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) No devices detected.
[ 901.661774] [ERROR]Aborting because fallback start is disabled.
While booting it also shows me the error:
ACPI PCC Probe failed
dmesg:
[ 0.358189] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.358246] pci 0000:09:00.0: System wakeup disabled by ACPI
[ 0.369899] pci 0000:00:1c.3: PCI bridge to [bus 09]
[ 0.369903] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
[ 0.369906] pci 0000:00:1c.3: bridge window [mem 0xb5400000-0xb54fffff]
[ 0.369994] pci 0000:0a:00.0: [10de:1292] type 00 class 0x030200
[ 0.370016] pci 0000:0a:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[ 0.370038] pci 0000:0a:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.370059] pci 0000:0a:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[ 0.370074] pci 0000:0a:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.370088] pci 0000:0a:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.381907] pci 0000:00:1c.4: PCI bridge to [bus 0a]
[ 0.381911] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 0.381914] pci 0000:00:1c.4: bridge window [mem 0xb3000000-0xb3ffffff]
[ 0.381919] pci 0000:00:1c.4: bridge window [mem 0xa0000000-0xb1ffffff 64bit pref]
[ 0.382593] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *7
[ 0.382646] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.382695] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.382745] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.382793] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.382842] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.382891] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.382939] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *7
[ 0.383089] ACPI: Enabled 4 GPEs in block 00 to 7F
[ 0.383145] ACPI : EC: GPE = 0x8, I/O: command/status = 0x66, data = 0x62
[ 0.383251] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.383254] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.383258] vgaarb: loaded
[ 0.383259] vgaarb: bridge control possible 0000:00:02.0
[ 0.383547] SCSI subsystem initialized
[ 0.383597] libata version 3.00 loaded.
[ 0.383622] ACPI: bus type USB registered
[ 0.383642] usbcore: registered new interface driver usbfs
[ 0.383651] usbcore: registered new interface driver hub
[ 0.383671] usbcore: registered new device driver usb
[ 0.383822] PCI: Using ACPI for IRQ routing
[ 0.389723] PCI: pci_cache_line_size set to 64 bytes
[ 0.389828] e820: reserve RAM buffer [mem 0x0009d400-0x0009ffff]
[ 0.389830] e820: reserve RAM buffer [mem 0x928af000-0x93ffffff]
[ 0.389832] e820: reserve RAM buffer [mem 0x93000000-0x93ffffff]
[ 0.389833] e820: reserve RAM buffer [mem 0x25f600000-0x25fffffff]
[ 0.389963] NetLabel: Initializing
[ 0.389965] NetLabel: domain hash size = 128
[ 0.389966] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.389979] NetLabel: unlabeled traffic allowed by default
[ 0.390040] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.390047] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.392085] Switched to clocksource hpet
[ 0.398666] AppArmor: AppArmor Filesystem Enabled
[ 0.398741] pnp: PnP ACPI init
[ 0.399056] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.399060] system 00:00: [io 0xffff] has been reserved
[ 0.399062] system 00:00: [io 0xffff] has been reserved
[ 0.399064] system 00:00: [io 0xffff] has been reserved
[ 0.399066] system 00:00: [io 0x1800-0x18fe] could not be reserved
[ 0.399068] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.399070] system 00:00: [io 0x0454-0x0457] has been reserved
[ 0.399072] system 00:00: [io 0x0380-0x0387] has been reserved
[ 0.399076] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.399129] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.399163] pnp 00:02: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
[ 0.399203] pnp 00:03: Plug and Play ACPI device, IDs SYN1ea5 SYN1e00 SYN0002 PNP0f13 (active)
[ 0.399422] pnp 00:04: disabling [mem 0xffffffff-0x100000ffe] because it overlaps 0000:0a:00.0 BAR 6 [mem 0xfff80000-0xffffffff pref]
[ 0.399445] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.399447] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.399450] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.399452] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.399454] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.399456] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.399458] system 00:04: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.399460] system 00:04: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.399462] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.399464] system 00:04: [mem 0x9fa10000-0x9fa10fff] has been reserved
[ 0.399467] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.399751] pnp: PnP ACPI: found 5 devices
[ 0.406084] pci 0000:0a:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.406096] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.406099] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000
[ 0.406101] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000
[ 0.406129] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.406131] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.406133] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.406138] pci 0000:00:1c.0: BAR 14: assigned [mem 0x9fb00000-0x9fcfffff]
[ 0.406143] pci 0000:00:1c.0: BAR 15: assigned [mem 0x9fd00000-0x9fefffff 64bit pref]
[ 0.406146] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.406149] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.406151] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.406156] pci 0000:00:1c.0: bridge window [mem 0x9fb00000-0x9fcfffff]
[ 0.406160] pci 0000:00:1c.0: bridge window [mem 0x9fd00000-0x9fefffff 64bit pref]
[ 0.406166] pci 0000:00:1c.1: PCI bridge to [bus 02-07]
[ 0.406168] pci 0000:00:1c.1: bridge window [io 0x5000-0x5fff]
[ 0.406173] pci 0000:00:1c.1: bridge window [mem 0xb4000000-0xb4ffffff]
[ 0.406176] pci 0000:00:1c.1: bridge window [mem 0xb2000000-0xb2ffffff 64bit pref]
[ 0.406182] pci 0000:00:1c.2: PCI bridge to [bus 08]
[ 0.406186] pci 0000:00:1c.2: bridge window [mem 0xb5500000-0xb55fffff]
[ 0.406194] pci 0000:00:1c.3: PCI bridge to [bus 09]
[ 0.406196] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
[ 0.406201] pci 0000:00:1c.3: bridge window [mem 0xb5400000-0xb54fffff]
[ 0.406210] pci 0000:0a:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[ 0.406212] pci 0000:0a:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[ 0.406214] pci 0000:00:1c.4: PCI bridge to [bus 0a]
[ 0.406216] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 0.406221] pci 0000:00:1c.4: bridge window [mem 0xb3000000-0xb3ffffff]
[ 0.406224] pci 0000:00:1c.4: bridge window [mem 0xa0000000-0xb1ffffff 64bit pref]
[ 0.406231] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.406233] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.406235] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.406237] pci_bus 0000:00: resource 7 [mem 0x9fa00000-0xfeafffff]
[ 0.406239] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.406240] pci_bus 0000:01: resource 1 [mem 0x9fb00000-0x9fcfffff]
[ 0.406242] pci_bus 0000:01: resource 2 [mem 0x9fd00000-0x9fefffff 64bit pref]
[ 0.406244] pci_bus 0000:02: resource 0 [io 0x5000-0x5fff]
[ 0.406246] pci_bus 0000:02: resource 1 [mem 0xb4000000-0xb4ffffff]
[ 0.406248] pci_bus 0000:02: resource 2 [mem 0xb2000000-0xb2ffffff 64bit pref]
[ 0.406250] pci_bus 0000:08: resource 1 [mem 0xb5500000-0xb55fffff]
[ 0.406252] pci_bus 0000:09: resource 0 [io 0x4000-0x4fff]
[ 0.406254] pci_bus 0000:09: resource 1 [mem 0xb5400000-0xb54fffff]
[ 0.406256] pci_bus 0000:0a: resource 0 [io 0x3000-0x3fff]
[ 0.406257] pci_bus 0000:0a: resource 1 [mem 0xb3000000-0xb3ffffff]
[ 0.406259] pci_bus 0000:0a: resource 2 [mem 0xa0000000-0xb1ffffff 64bit pref]
[ 0.406291] NET: Registered protocol family 2
[ 0.406509] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.406682] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.406828] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.406849] TCP: reno registered
[ 0.406862] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.406894] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.406954] NET: Registered protocol family 1
[ 0.406970] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.424281] PCI: CLS 64 bytes, default 64
[ 0.424340] Trying to unpack rootfs image as initramfs...
[ 0.814014] Freeing initrd memory: 19340K (ffff880035a2a000 - ffff880036d0d000)
[ 0.814038] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.814041] software IO TLB [mem 0x8e8af000-0x928af000] (64MB) mapped at [ffff88008e8af000-ffff8800928aefff]
[ 0.814080] Simple Boot Flag at 0x44 set to 0x1
[ 0.814258] RAPL PMU detected, hw unit 2^-14 Joules, API unit is 2^-32 Joules, 4 fixed counters 655360 ms ovfl timer
[ 0.814318] microcode: CPU0 sig=0x40651, pf=0x40, revision=0x14
[ 0.814326] microcode: CPU1 sig=0x40651, pf=0x40, revision=0x14
[ 0.814335] microcode: CPU2 sig=0x40651, pf=0x40, revision=0x14
[ 0.814344] microcode: CPU3 sig=0x40651, pf=0x40, revision=0x14
[ 0.814397] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.814430] Scanning for low memory corruption every 60 seconds
[ 0.814834] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.814861] Initialise system trusted keyring
[ 0.814889] audit: initializing netlink subsys (disabled)
[ 0.814902] audit: type=2000 audit(1443038400.796:1): initialized
[ 0.815285] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.817036] zpool: loaded
[ 0.817041] zbud: loaded
[ 0.817227] VFS: Disk quotas dquot_6.5.2
[ 0.817269] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.817796] fuse init (API version 7.23)
[ 0.817958] Key type big_key registered
[ 0.818348] Key type asymmetric registered
[ 0.818352] Asymmetric key parser 'x509' registered
[ 0.818393] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.818432] io scheduler noop registered
[ 0.818436] io scheduler deadline registered (default)
[ 0.818471] io scheduler cfq registered
[ 0.819175] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.819193] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.819237] intel_idle: MWAIT substates: 0x11142120
[ 0.819238] intel_idle: v0.4 model 0x45
[ 0.819239] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.819843] ACPI: AC Adapter [ACAD] (on-line)
[ 0.819950] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.820477] ACPI: Lid Switch [LID0]
[ 0.820525] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.820529] ACPI: Power Button [PWRB]
[ 0.820578] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.820580] ACPI: Power Button [PWRF]
[ 0.821732] [Firmware Bug]: Invalid critical threshold (0)
[ 0.823437] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.823439] ACPI: Thermal Zone [TZ01] (51 C)
[ 0.823480] GHES: HEST is not enabled!
[ 0.823612] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.825707] Linux agpgart interface v0.103
[ 0.827083] brd: module loaded
[ 0.827728] loop: module loaded
[ 0.827967] libphy: Fixed MDIO Bus: probed
[ 0.827970] tun: Universal TUN/TAP device driver, 1.6
[ 0.827972] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.828017] PPP generic driver version 2.4.2
[ 0.828188] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.828195] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.828274] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.828353] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.828355] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.828357] usb usb1: Product: xHCI Host Controller
[ 0.828359] usb usb1: Manufacturer: Linux 3.19.0-28-generic xhci-hcd
[ 0.828360] usb usb1: SerialNumber: 0000:00:14.0
[ 0.828488] hub 1-0:1.0: USB hub found
[ 0.828500] hub 1-0:1.0: 9 ports detected
[ 0.829044] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.829048] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.829081] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.829083] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.829085] usb usb2: Product: xHCI Host Controller
[ 0.829086] usb usb2: Manufacturer: Linux 3.19.0-28-generic xhci-hcd
[ 0.829088] usb usb2: SerialNumber: 0000:00:14.0
[ 0.829191] hub 2-0:1.0: USB hub found
[ 0.829199] hub 2-0:1.0: 4 ports detected
[ 0.829529] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.829535] ehci-pci: EHCI PCI platform driver
[ 0.829651] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.829657] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 0.829668] ehci-pci 0000:00:1d.0: debug port 2
[ 0.833587] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.833602] ehci-pci 0000:00:1d.0: irq 23, io mem 0xb561c000
[ 0.844462] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.844501] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.844503] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.844504] usb usb3: Product: EHCI Host Controller
[ 0.844506] usb usb3: Manufacturer: Linux 3.19.0-28-generic ehci_hcd
[ 0.844508] usb usb3: SerialNumber: 0000:00:1d.0
[ 0.844639] hub 3-0:1.0: USB hub found
[ 0.844644] hub 3-0:1.0: 2 ports detected
[ 0.844766] ehci-platform: EHCI generic platform driver
[ 0.844776] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.844781] ohci-pci: OHCI PCI platform driver
[ 0.844793] ohci-platform: OHCI generic platform driver
[ 0.844801] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.844853] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.852479] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.852485] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.852660] mousedev: PS/2 mouse device common for all mice
[ 0.852892] rtc_cmos 00:01: RTC can wake from S4
[ 0.853041] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 0.853069] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.853086] i2c /dev entries driver
[ 0.853156] device-mapper: uevent: version 1.0.3
[ 0.853249] device-mapper: ioctl: 4.29.0-ioctl (2014-10-28) initialised: dm-devel@redhat.com
[ 0.853269] Intel P-state driver initializing.
[ 0.853386] Consider also installing thermald for improved thermal control.
[ 0.853393] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.853563] PCCT header not found.
[ 0.853565] ACPI PCC probe failed.
[ 0.853685] TCP: cubic registered
[ 0.853790] NET: Registered protocol family 10
[ 0.854033] NET: Registered protocol family 17
[ 0.854044] Key type dns_resolver registered
[ 0.854339] Loading compiled-in X.509 certificates
[ 0.855226] Loaded X.509 cert 'Magrathea: Glacier signing key: 294dc012706f48b7cddf6374e2d79fe1b0609269'
[ 0.855239] registered taskstats version 1
[ 0.856783] Key type trusted registered
[ 0.859280] Key type encrypted registered
[ 0.859287] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.859291] ima: No TPM chip found, activating TPM-bypass!
[ 0.859310] evm: HMAC attrs: 0x1
[ 0.859761] Magic number: 15:829:43
[ 0.859846] rtc_cmos 00:01: setting system clock to 2015-09-23 20:00:01 UTC (1443038401)
[ 0.859889] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.859890] EDD information not available.
[ 0.859940] PM: Hibernation image not present or could not be loaded.
[ 0.861000] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.882504] ACPI: Battery Slot [BAT0] (battery present)
[ 0.882848] Freeing unused kernel memory: 1408K (ffffffff81d27000 - ffffffff81e87000)
[ 0.882850] Write protecting the kernel read-only data: 12288k
[ 0.883093] Freeing unused kernel memory: 260K (ffff8800017bf000 - ffff880001800000)
[ 0.883189] Freeing unused kernel memory: 340K (ffff880001bab000 - ffff880001c00000)
[ 0.894178] systemd-udevd[119]: starting version 204
[ 0.911813] rtsx_pci 0000:02:00.0: rtsx_pci_acquire_irq: pcr->msi_en = 1, pci->irq = 41
[ 0.913780] ahci 0000:00:1f.2: version 3.0
[ 0.914062] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.914070] r8169 0000:09:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.922157] r8169 0000:09:00.0 eth0: RTL8106e at 0xffffc90010e9e000, a0:48:1c:16:b3:a2, XID 10900800 IRQ 43
[ 0.928547] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x3 impl SATA mode
[ 0.928553] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[ 0.929497] scsi host0: ahci
[ 0.929644] scsi host1: ahci
[ 0.929728] scsi host2: ahci
[ 0.929809] scsi host3: ahci
[ 0.929848] ata1: SATA max UDMA/133 abar m2048@0xb561b000 port 0xb561b100 irq 42
[ 0.929850] ata2: SATA max UDMA/133 abar m2048@0xb561b000 port 0xb561b180 irq 42
[ 0.929851] ata3: DUMMY
[ 0.929852] ata4: DUMMY
[ 1.140766] usb 1-1: new low-speed USB device number 2 using xhci_hcd
[ 1.156773] usb 3-1: new high-speed USB device number 2 using ehci-pci
[ 1.248848] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.248869] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.250574] ata2.00: ATAPI: hp DVDRAM GU70N, U703, max UDMA/100
[ 1.250763] ata1.00: ATA-9: HGST HTS541010A9E680, JA0OA590, max UDMA/133
[ 1.250768] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.252492] ata2.00: configured for UDMA/100
[ 1.252835] ata1.00: configured for UDMA/133
[ 1.253012] scsi 0:0:0:0: Direct-Access ATA HGST HTS541010A9 A590 PQ: 0 ANSI: 5
[ 1.253370] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 1.253375] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.253414] sd 0:0:0:0: [sda] Write Protect is off
[ 1.253418] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.253429] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.253432] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.253930] scsi 1:0:0:0: CD-ROM hp DVDRAM GU70N U703 PQ: 0 ANSI: 5
[ 1.270922] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.270926] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.271153] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.271267] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.289318] usb 3-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.289323] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.289605] hub 3-1:1.0: USB hub found
[ 1.289803] hub 3-1:1.0: 8 ports detected
[ 1.325818] sda: sda1 sda2 sda3 < sda5 sda6 >
[ 1.326688] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.329995] usb 1-1: New USB device found, idVendor=413c, idProduct=2106
[ 1.330008] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.330010] usb 1-1: Product: Dell QuietKey Keyboard
[ 1.330011] usb 1-1: Manufacturer: DELL
[ 1.330147] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.333344] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.336929] usbcore: registered new interface driver usbhid
[ 1.336933] usbhid: USB HID core driver
[ 1.338546] input: DELL Dell QuietKey Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:413C:2106.0001/input/input6
[ 1.393103] hid-generic 0003:413C:2106.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell QuietKey Keyboard] on usb-0000:00:14.0-1/input0
[ 1.444955] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[ 1.674697] usb 1-3: New USB device found, idVendor=05c8, idProduct=0361
[ 1.674701] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.674703] usb 1-3: Product: HP Truevision HD
[ 1.674705] usb 1-3: Manufacturer: SunplusIT INC.
[ 1.797729] psmouse serio1: synaptics: queried max coordinates: x [..5696], y [..4884]
[ 1.813264] tsc: Refined TSC clocksource calibration: 2394.456 MHz
[ 1.832921] psmouse serio1: synaptics: queried min coordinates: x [1276..], y [1044..]
[ 1.899972] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1c0b1, caps: 0xf00133/0x240000/0xa2400, board id: 2665, fw id: 1458825
[ 1.909343] usb 1-6: new low-speed USB device number 4 using xhci_hcd
[ 1.943053] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input5
[ 1.950639] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.041203] usb 1-6: New USB device found, idVendor=413c, idProduct=3012
[ 2.041207] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.041209] usb 1-6: Product: Dell USB Optical Mouse
[ 2.041211] usb 1-6: Manufacturer: Dell
[ 2.041390] usb 1-6: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.043426] input: Dell Dell USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:413C:3012.0002/input/input7
[ 2.043826] hid-generic 0003:413C:3012.0002: input,hidraw1: USB HID v1.11 Mouse [Dell Dell USB Optical Mouse] on usb-0000:00:14.0-6/input0
[ 2.429393] random: nonblocking pool is initialized
[ 2.814167] Switched to clocksource tsc
[ 3.092648] init: plymouth-upstart-bridge main process (190) terminated with status 1
[ 3.092658] init: plymouth-upstart-bridge main process ended, respawning
[ 3.094649] init: plymouth-upstart-bridge main process (205) terminated with status 1
[ 3.094663] init: plymouth-upstart-bridge main process ended, respawning
[ 3.095886] init: plymouth-upstart-bridge main process (207) terminated with status 1
[ 3.095893] init: plymouth-upstart-bridge main process ended, respawning
[ 3.097479] init: plymouth-upstart-bridge main process (208) terminated with status 1
[ 3.097486] init: plymouth-upstart-bridge main process ended, respawning
[ 3.098610] init: plymouth-upstart-bridge main process (210) terminated with status 1
[ 3.098617] init: plymouth-upstart-bridge main process ended, respawning
[ 3.100299] init: plymouth-upstart-bridge main process (211) terminated with status 1
[ 3.100308] init: plymouth-upstart-bridge main process ended, respawning
[ 3.101618] init: plymouth-upstart-bridge main process (213) terminated with status 1
[ 3.101626] init: plymouth-upstart-bridge main process ended, respawning
[ 3.103577] init: plymouth-upstart-bridge main process (214) terminated with status 1
[ 3.103592] init: plymouth-upstart-bridge main process ended, respawning
[ 3.105290] init: plymouth-upstart-bridge main process (216) terminated with status 1
[ 3.105310] init: plymouth-upstart-bridge main process ended, respawning
[ 3.106586] init: plymouth-upstart-bridge main process (217) terminated with status 1
[ 3.106592] init: plymouth-upstart-bridge main process ended, respawning
[ 3.107810] init: plymouth-upstart-bridge main process (219) terminated with status 1
[ 3.107817] init: plymouth-upstart-bridge respawning too fast, stopped
[ 4.073328] Adding 7999484k swap on /dev/sda2. Priority:-1 extents:1 across:7999484k FS
[ 4.800214] systemd-udevd[321]: starting version 204
[ 5.617174] lp: driver loaded but no devices found
[ 5.733314] ppdev: user-space parallel port driver
[ 6.317127] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[ 7.261385] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 8.127871] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.132477] wmi: Mapper loaded
[ 8.166487] hp_accel: laptop model unknown, using default axes configuration
[ 8.174674] lis3lv02d: 8 bits 3DC sensor found
[ 8.218509] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input8
[ 8.282998] Initializing HPQ6001 module
[ 8.283070] input: HP Wireless hotkeys as /devices/virtual/input/input9
[ 8.494571] [drm] Initialized drm 1.1.0 20060810
[ 8.552443] cfg80211: Calling CRDA to update world regulatory domain
[ 8.698212] media: Linux media interface: v0.10
[ 8.717285] Linux video capture interface: v2.00
[ 8.731235] Intel(R) Wireless WiFi driver for Linux, in-tree:
[ 8.731237] Copyright(c) 2003- 2014 Intel Corporation
[ 8.731373] iwlwifi 0000:08:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 8.978129] input: HP WMI hotkeys as /devices/virtual/input/input10
[ 9.028940] AVX2 version of gcm_enc/dec engaged.
[ 9.028943] AES CTR mode by8 optimization enabled
[ 9.055443] iwlwifi 0000:08:00.0: loaded firmware version 8.83.5.1 build 33692 op_mode iwldvm
[ 9.120135] uvcvideo: Found UVC 1.00 device HP Truevision HD (05c8:0361)
[ 9.128619] input: HP Truevision HD as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input11
[ 9.128717] usbcore: registered new interface driver uvcvideo
[ 9.128720] USB Video Class driver (1.1.1)
[ 9.178048] [drm] Memory usable by graphics device = 2048M
[ 9.178052] [drm] Replacing VGA console driver
[ 9.179136] Console: switching to colour dummy device 80x25
[ 9.203271] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 9.203273] [drm] Driver supports precise vblank timestamp query.
[ 9.203379] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 9.269013] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 9.269338] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 9.269343] ACPI Error: [\_SB_.PCI0.GFX0.DD02._BCL] Namespace lookup failure, AE_NOT_FOUND (20141107/psargs-359)
[ 9.269348] ACPI Error: Method parse/execution failed [\_SB_.PCI0.RP05.PEGP.DD02._BCL] (Node ffff8802568e29b0), AE_NOT_FOUND (20141107/psparse-536)
[ 9.269408] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/LNXVIDEO:00/input/input12
[ 9.270795] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 9.270937] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input13
[ 9.270993] [drm] Initialized i915 1.6.0 20141121 for 0000:00:02.0 on minor 0
[ 9.271125] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 9.294533] fbcon: inteldrmfb (fb0) is primary device
[ 9.317211] sound hdaudioC1D0: autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 9.317212] sound hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 9.317213] sound hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 9.317214] sound hdaudioC1D0: mono: mono_out=0x0
[ 9.317214] sound hdaudioC1D0: inputs:
[ 9.317215] sound hdaudioC1D0: Mic=0x19
[ 9.317216] sound hdaudioC1D0: Internal Mic=0x12
[ 9.324000] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input14
[ 9.324274] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15
[ 9.324957] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input16
[ 9.489551] iwlwifi 0000:08:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 9.489552] iwlwifi 0000:08:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 9.489552] iwlwifi 0000:08:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 9.489554] iwlwifi 0000:08:00.0: Detected Intel(R) WiFi Link 5100 AGN, REV=0x54
[ 9.489652] iwlwifi 0000:08:00.0: L1 Enabled - LTR Disabled
[ 9.624595] kvm: disabled by bios
[ 9.648596] kvm: disabled by bios
[ 9.649487] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 9.855690] cfg80211: World regulatory domain updated:
[ 9.855692] cfg80211: DFS Master region: unset
[ 9.855692] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.855694] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 9.855696] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 9.855697] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 9.855697] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 9.855698] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 10.026708] intel_rapl: Found RAPL domain package
[ 10.026710] intel_rapl: Found RAPL domain core
[ 10.026711] intel_rapl: Found RAPL domain uncore
[ 10.026713] intel_rapl: Found RAPL domain dram
[ 10.229704] audit: type=1400 audit(1443038410.856:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=504 comm="apparmor_parser"
[ 10.229709] audit: type=1400 audit(1443038410.856:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=504 comm="apparmor_parser"
[ 10.229712] audit: type=1400 audit(1443038410.856:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=504 comm="apparmor_parser"
[ 10.229948] audit: type=1400 audit(1443038410.856:5): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=505 comm="apparmor_parser"
[ 10.229956] audit: type=1400 audit(1443038410.856:6): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=505 comm="apparmor_parser"
[ 10.229961] audit: type=1400 audit(1443038410.856:7): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=505 comm="apparmor_parser"
[ 10.229970] audit: type=1400 audit(1443038410.856:8): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=565 comm="apparmor_parser"
[ 10.229976] audit: type=1400 audit(1443038410.856:9): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=565 comm="apparmor_parser"
[ 10.229982] audit: type=1400 audit(1443038410.856:10): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=565 comm="apparmor_parser"
[ 10.230137] audit: type=1400 audit(1443038410.856:11): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=504 comm="apparmor_parser"
[ 10.388190] Console: switching to colour frame buffer device 160x48
[ 10.393109] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 10.393110] i915 0000:00:02.0: registered panic notifier
[ 10.869671] init: failsafe main process (590) killed by TERM signal
[ 11.891540] init: avahi-cups-reload main process (791) terminated with status 1
[ 12.702241] Bluetooth: Core ver 2.20
[ 12.702253] NET: Registered protocol family 31
[ 12.702254] Bluetooth: HCI device and connection manager initialized
[ 12.702257] Bluetooth: HCI socket layer initialized
[ 12.702259] Bluetooth: L2CAP socket layer initialized
[ 12.702263] Bluetooth: SCO socket layer initialized
[ 12.871594] Bluetooth: RFCOMM TTY layer initialized
[ 12.871599] Bluetooth: RFCOMM socket layer initialized
[ 12.871604] Bluetooth: RFCOMM ver 1.11
[ 12.960064] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.960067] Bluetooth: BNEP filters: protocol multicast
[ 12.960071] Bluetooth: BNEP socket layer initialized
[ 15.178134] r8169 0000:09:00.0 eth0: link down
[ 15.178156] r8169 0000:09:00.0 eth0: link down
[ 15.178175] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.446191] init: smbd main process (656) killed by HUP signal
[ 15.446198] init: smbd main process ended, respawning
[ 15.539600] audit_printk_skb: 33 callbacks suppressed
[ 15.539604] audit: type=1400 audit(1443038416.164:23): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=853 comm="apparmor_parser"
[ 16.844267] audit: type=1400 audit(1443038417.464:24): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=901 comm="apparmor_parser"
[ 16.844275] audit: type=1400 audit(1443038417.464:25): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=901 comm="apparmor_parser"
[ 16.844280] audit: type=1400 audit(1443038417.464:26): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=901 comm="apparmor_parser"
[ 16.844698] audit: type=1400 audit(1443038417.464:27): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=901 comm="apparmor_parser"
[ 16.844702] audit: type=1400 audit(1443038417.464:28): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=901 comm="apparmor_parser"
[ 16.844839] audit: type=1400 audit(1443038417.464:29): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=901 comm="apparmor_parser"
[ 16.846377] audit: type=1400 audit(1443038417.468:30): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cups-browsed" pid=905 comm="apparmor_parser"
[ 16.848523] audit: type=1400 audit(1443038417.468:31): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=906 comm="apparmor_parser"
[ 16.848527] audit: type=1400 audit(1443038417.468:32): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=906 comm="apparmor_parser"
[ 17.510735] init: samba-ad-dc main process (839) terminated with status 1
[ 21.248120] bbswitch: module verification failed: signature and/or required key missing - tainting kernel
[ 21.248395] bbswitch: version 0.8
[ 21.248402] bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
[ 21.248410] bbswitch: Found discrete VGA device 0000:0a:00.0: \_SB_.PCI0.RP05.PEGP
[ 21.248423] ACPI Warning: \_SB_.PCI0.RP05.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20141107/nsarguments-95)
[ 21.248514] bbswitch: detected an Optimus _DSM function
[ 21.248531] pci 0000:0a:00.0: enabling device (0006 -> 0007)
[ 21.248576] bbswitch: Succesfully loaded. Discrete card 0000:0a:00.0 is on
[ 21.250658] bbswitch: disabling discrete graphics
[ 21.250665] ACPI Warning: \_SB_.PCI0.RP05.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20141107/nsarguments-95)
[ 21.897869] r8169 0000:09:00.0 eth0: link up
[ 21.897879] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 150.465475] bbswitch: enabling discrete graphics
[ 151.238577] nvidia: module license 'NVIDIA' taints kernel.
[ 151.238586] Disabling lock debugging due to kernel taint
[ 151.258781] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:0a:00.0 on minor 1
[ 151.258797] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 340.76 Thu Jan 22 12:11:08 PST 2015
