System: GTX 3070ti (FE), Ryzen 5600x, 32GB RAM, 2560x1440@170Hz (desktop system)
Output of nvidia-bug-report.sh: UNTITLED - Pastebin Service
Driver version: 510.68.02 from RPM Fusion repositories
Distro: Fedora 36 (clean install)
I tried to install the proprietary driver from RPM Fusion but it causes boot to hang with the error message “Failed to start nvidia-powerd.service”.
I don’t think that it is a wayland or X server issue - it comes before it in the boot process and I tried to troubleshoot it by booting to the text console with the same results.
This system previously ran fine on Fedora 35 and X server is useable with the nouveau driver.
The only similar issue that I can find on google is this /r/Fedora/comments/unfbel/fedora_36_akmodnvidia_driver/
(sorry, the forum only allows me to put in one link!)
Thanks for your help in advance!
Output of systemctl status nvidia-powerd.service:
× nvidia-powerd.service - nvidia-powerd service
Loaded: loaded (/usr/lib/systemd/system/nvidia-powerd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-05-30 17:26:37 BST; 2min 15s ago
Process: 1052 ExecStart=/usr/bin/nvidia-powerd (code=exited, status=1/FAILURE)
Main PID: 1052 (code=exited, status=1/FAILURE)
CPU: 4ms
May 30 17:26:37 gimli systemd[1]: Starting nvidia-powerd.service - nvidia-powerd service...
May 30 17:26:37 gimli /usr/bin/nvidia-powerd[1052]: nvidia-powerd version:1.0(build 1)
May 30 17:26:37 gimli /usr/bin/nvidia-powerd[1052]: Allocate client failed 38
May 30 17:26:37 gimli /usr/bin/nvidia-powerd[1052]: Failed to initialize RM Client
May 30 17:26:37 gimli systemd[1]: nvidia-powerd.service: Main process exited, code=exited, status=1/FAILURE
May 30 17:26:37 gimli systemd[1]: nvidia-powerd.service: Failed with result 'exit-code'.
May 30 17:26:37 gimli systemd[1]: Failed to start nvidia-powerd.service - nvidia-powerd service.
Picture of the boot screen with plymouth disabled: https://photos.app.goo.gl/XfaYFSyB6fN4RdPq6
(note the multicoloured bar 1/3 of the way down the screen is real - it’s not an artifact of the camera!)
Uploading output of nvidia-bug-report.sh in this post. It won’t allow me to attach to the first post due to number of links allowed for new users.
nvidia-bug-report.log.gz (81.3 KB)
There are no nvidia modules available. Please try reinstalling kernel headers and driver.
Thanks generix.
I’ve already tried this unfortunately. I did a second clean install of Fedora 36 and installed the driver with the same result. I also tried uninstalling the driver and reinstalling with the same result.
I ran the various debug commands using nouveau since I couldn’t boot using the proprietary driver. Is that maybe why it’s showing the modules as unavailable?
For reference, I used the instructions here: Howto/NVIDIA - RPM Fusion I made sure that I was on the latest kernel and rebooted prior to doing the installation as per instructions. I also let the computer sit for 15 mins and checked htop that there were no processes running to ensure that it had fully built.
I have this trouble on my Fedora 36
If I restart the service, my Fedora back to work
So I do systemctl stop nvidia-powerd.service ;
sudo dnf reinstall xorg-x11-drv-nvidia-cuda-3:515.57.-1.fc36.*
systemctl start nvidia-powerd.service
