i download all this:
cuda-downloads?target_os=Windows&target_arch=x86_64&target_version=10&target_type=exe_local
and
us.download.nvidia.com/Windows/536.67/536.67-desktop-win10-win11-64bit-international-nsd-dch-whql.exe
and
international.download.nvidia.com/Windows/broadcast/sdk/VFX/nvidia_video_effects_sdk_installer_v0.7.2_ampere.exe
this is my run.bat
SETLOCAL
SET PATH=%PATH%;..\..\samples\external\opencv\bin;..\..\bin;
SET NVAR_MODEL_DIR=..\..\bin\models
GazeRedirect.exe --offline_mode --split_screen_view=false --in=presentacion.mp4
and show this error
D:\Users\ZALMAN\Downloads\MAXINE-AR-SDK-0.8.2.0\samples\GazeRedirect>run.bat
D:\Users\ZALMAN\Downloads\MAXINE-AR-SDK-0.8.2.0\samples\GazeRedirect>SETLOCAL
D:\Users\ZALMAN\Downloads\MAXINE-AR-SDK-0.8.2.0\samples\GazeRedirect>SET PATH=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.2\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.2\libnvvp;C:\Program Files (x86)\VMware\VMware Workstation\bin\;C:\Python311\Scripts\;C:\Python311\;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Program Files\Microsoft\jdk-11.0.16.101-hotspot\bin;C:\Program Files\Microsoft\jdk-17.0.7.7-hotspot\bin;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\PuTTY\;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files\Microsoft SQL Server\150\Tools\Binn\;F:\Users\GAMEMAX\Documents\MICHAELPAGE\APLICACIONES Y EJECUTABLES\sonar-scanner-msbuild-5.13.0.66756-net46;C:\Program Files\Microsoft Visual Studio\2022\Enterprise\MSBuild\Current\Bin;F:\Users\GAMEMAX\Documents\MICHAELPAGE\APLICACIONES Y EJECUTABLES\sonar-scanner-cli-4.8.0.2856-windows\sonar-scanner-4.8.0.2856-windows\bin;C:\Program Files\nodejs\;C:\ProgramData\chocolatey\bin;C:\Program Files\Git\cmd;C:\Program Files\NVIDIA Corporation\Nsight Compute 2023.2.0\;C:\Users\ZALMAN\AppData\Local\Microsoft\WindowsApps;C:\Users\ZALMAN\.dotnet\tools;C:\Users\ZALMAN\AppData\Roaming\npm;C:\Users\ZALMAN\AppData\Local\GitHubDesktop\bin;..\..\samples\external\opencv\bin;..\..\bin;
D:\Users\ZALMAN\Downloads\MAXINE-AR-SDK-0.8.2.0\samples\GazeRedirect>SET NVAR_MODEL_DIR=..\..\bin\models
D:\Users\ZALMAN\Downloads\MAXINE-AR-SDK-0.8.2.0\samples\GazeRedirect>GazeRedirect.exe --offline_mode --split_screen_view=false --in=presentacion.mp4
Cannot create a cuda stream: Error loading the dynamic library
ERROR: Initializing Gaze Engine failed
how fix this?
