Make sure that you’ve installed the Visual C++ components of VS 2015.
If everything is configured correctly, you should be able to choose a Visual C++ Windows console application template in the new project wizard.
If nothing helps, please gather the installer log files using the tool [url]Bing and attach them to the thread.
The recently released Nsight Tegra Visual Studio Edition 3.5 fully supports VS 2017.
Please make sure that you’ve installed the VS workload named Visual C++ for desktop development before running NT VSE’s installer.
It seems that you’ve customized the VS 2017 Community 15.6 installation path, so the directory C:\Program Files (x86)\Microsoft Visual Studio\2017\ doesn’t exist on the PC.
To unblock the MSI installer, try to manually create an empty directory C:\Program Files (x86)\Microsoft Visual Studio\2017\
Please, attach the MD5 of the installer’s executable and installer log files, located in %tmp% directory.
Thank you.
As a workaround, you can extract the .VSIX extension package out of the .MSI file and install it by hand using VS 2017’s VSIX installer.
The exact procedure is described in the topic dedicated to VS 2017 support.
“Installing Nsight Tegra, Visual Studio Edition 3.5 failed
Return code: 2
Cannot detect Visual Studio(2010|2012|2013|2015|2017) on your system. Please install…”
But I have installed Visual Studio Community 2017 (see details of the version below)
Visual Studio Community 2017 installation info (extract)
Microsoft Visual Studio Community 2017
Version 15.8.6
VisualStudio.15.Release/15.8.6+28010.2041
Microsoft .NET Framework
Version 4.7.02558
Installed Version: Community
Visual C++ 2017 00369-60000-00001-AA401
Microsoft Visual C++ 2017
I have tried to create manually the empty directory (as luispmelgar did), but it sounds not enough
I don't understand the suggestions done by MikhailFiliminov about the MD5 or the workaround
Could you please provide any kind of support?
Hi fred.cheneviere, we encourage you to try out the 3.6 release published a couple of months ago.
In case of emergency, please collect the installation logs stored in C:\Program Files (x86)\NVIDIA Corporation\Nsight Tegra 3.6 and attach them here.
As a last resort, you can manually install the extension package C:\Program Files (x86)\NVIDIA Corporation\Nsight Tegra 3.x\Nvidia.PentaK.vsix - it should work in any case.
Hello, it seems that the release 3.6 is now unlisted from the download center. Sorry for the confusion, we’ll look into that.
As of now, I suggest as a workaround to locate the extension’s VSIX container in Program Files under NVIDIA root directory and install it manually via VSIX installer. Double-click in Explorer should suffice to launch the installation process.
I installed Nsight Tegra 3.5 manually from the NVIDEA > CodeWorksforAndroid folder. Then the Nvidea Codeworks 1R7 installer again, without the Nisight Tegra component. So far, so good…
