I used SDK manager to install Jetpack 4.4 on Jetson NX. But it failed to execute commands with GenericInstaller.
10:04:07 INFO: Flash Jetson Xavier NX: **********************
10:04:07 INFO: Flash Jetson Xavier NX: #!/bin/bash
10:04:07 INFO: Flash Jetson Xavier NX: set -e
10:04:07 INFO: Flash Jetson Xavier NX: if [ -e ./bootloader/system.img ]; then
10:04:07 INFO: Flash Jetson Xavier NX: echo sudo ./flash.sh --no-systemimg jetson-xavier-nx-devkit-emmc mmcblk0p1
10:04:07 INFO: Flash Jetson Xavier NX: sudo ./flash.sh --no-systemimg jetson-xavier-nx-devkit-emmc mmcblk0p1
10:04:07 INFO: Flash Jetson Xavier NX: else
10:04:07 INFO: Flash Jetson Xavier NX: echo sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
10:04:07 INFO: Flash Jetson Xavier NX: sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
10:04:07 INFO: Flash Jetson Xavier NX: fi
10:04:07 INFO: Flash Jetson Xavier NX: sleep 20
10:04:07 INFO: Flash Jetson Xavier NX: exec_command: /tmp/tmp_NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP.sh
10:04:07 INFO: Flash Jetson Xavier NX: ###############################################################################
10:04:07 INFO: Flash Jetson Xavier NX: # L4T BSP Information:
10:04:07 INFO: Flash Jetson Xavier NX: # R32 , REVISION: 4.3
10:04:07 INFO: Flash Jetson Xavier NX: # Target Board Information:
10:04:07 INFO: Flash Jetson Xavier NX: # Name: jetson-xavier-nx-devkit-emmc, Board Family: t186ref, SoC: Unknown,
10:04:07 INFO: Flash Jetson Xavier NX: # OpMode: pre-production, Boot Authentication: ,
10:04:07 INFO: Flash Jetson Xavier NX: Error: The Actual SoC ID(0x00) mismatches intended jetson-xavier-nx-devkit-emmc SoC ID(0x19).
10:04:07 INFO: Flash Jetson Xavier NX: [ Component Install Finished with Error ]
10:04:07 INFO: Flash Jetson Xavier NX: [ 12.00 KB used. Disk Avail: 366.96 GB ]
10:04:07 INFO: Flash Jetson Xavier NX: [ NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP Install took 1s ]
10:04:07 SUMMARY: Flash Jetson Xavier NX: Failed to execute commands with GenericInstaller
