This is the error I get when trying to load Hello World
Using Isaac Sim 2022.2.1
2023-06-12 17:29:23 [42,131ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished coro=<BaseSampleExtension._on_load_world.<locals>._on_load_world_async() done, defined at c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.examples\omni\isaac\examples\base_sample\base_sample_extension.py:150> exception=AttributeError("'NoneType' object has no attribute 'GetPath'")>
File "c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.examples\omni\isaac\examples\base_sample\base_sample_extension.py", line 151, in _on_load_world_async
await self._sample.load_world_async()
File "c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.examples\omni\isaac\examples\base_sample\base_sample.py", line 43, in load_world_async
self.setup_scene()
File "c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.examples\omni\isaac\examples\hello_world\hello_world.py", line 22, in setup_scene
world.scene.add_default_ground_plane()
File "c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core\omni\isaac\core\scenes\scene.py", line 223, in add_default_ground_plane
plane = GroundPlane(prim_path=prim_path, name=name, z_position=z_position, physics_material=physics_material)
File "c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core\omni\isaac\core\objects\ground_plane.py", line 94, in __init__
get_first_matching_child_prim(prim_path=prim_path, predicate=lambda x: get_prim_type_name(x) == "Plane")
File "c:\users\linca\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.core\omni\isaac\core\utils\prims.py", line 304, in get_prim_path
return prim.GetPath().pathString
AttributeError: 'NoneType' object has no attribute 'GetPath'
