I have mounted the CAN0 and CAN1 when i check with ifconfig command. But When i used can-utils to test the data transmittion…there haven’t any received the data…please comment what wrong that i done. Thank You
Have you followed the instruction at Controller Area Network (CAN) — Jetson Linux Developer Guide documentation (nvidia.com)?
I have received the data after I added a 120 Ohm resistor with CAN_H and CAN_L. Thank You for your help!!
