when using the below command to run my custom yolov3tiny model with python bindings of deep stream the code does not move ahead.
$ sudo python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4
Unknown or legacy key specified ‘is-classifier’ for group [property]
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
Opening in BLOCKING MODE
Deserialize yoloLayerV3 plugin: yolo_17
Deserialize yoloLayerV3 plugin: yolo_24
0:00:10.978689944 2058 0x6260190 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/model_b1_gpu0_fp32.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT data 3x416x416
1 OUTPUT kFLOAT yolo_17 45x13x13
2 OUTPUT kFLOAT yolo_24 45x26x26
0:00:10.979101819 2058 0x6260190 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/model_b1_gpu0_fp32.engine
0:00:11.088726038 2058 0x6260190 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
no errors are shown and the code does not move past this point
