Nope. I’ve done both and issue remains :/
One thing…
grep modeset /etc/modprobe.d/* /lib/modprobe.d/*
/lib/modprobe.d/nvidia-kms.conf:# Set value to 0 to disable modesetting
/lib/modprobe.d/nvidia-kms.conf:options nvidia-drm modeset=1
i had a similar issue with my previous PC, you guys helped me and the issue was resolved changing modeset to 0. Should i give it a try?
Hi again!
I’ve tried what i said in previous comment but everything is the same (PC freezes after login).
Any more ideas?
Cheers
Can you please create a new, empty user profile and check if you can log into that to rule out any side effects?
unfortunately it happens exactly the same…
Taking your previous strange dkms failure into account, I think you should consider a clean reinstall of the OS. Last try before could be a downgrade to the 418 driver to rule out some odd and unlikely driver bug.
Should i / can i download the driver from nvidia website?
Don’t use the .run installer, try to pull it from the ppa:
sudo apt install nvidia-driver-418
Hmm…
2019-08-23 16:34:02 joseph@jps ~ sudo apt install nvidia-driver-418
[sudo] password for joseph:
Reading package lists... Done
Building dependency tree
Reading state information... Done
nvidia-driver-418 is already the newest version (430.40-0ubuntu0~gpu18.04.1).
0 upgraded, 0 newly installed, 0 to remove and 82 not upgraded.
This is strange, no?
This is because 430 is and update to 418. I’m not really sure about downgrading and preventing update, maybe first purge the driver and then block 430:
sudo apt purge nvidia-*
sudo apt-mark hold nvidia-driver-430
E: Unable to locate package nvidia-bug-report-20190806_1537.log.gz
E: Couldn't find any package by glob 'nvidia-bug-report-20190806_1537.log.gz'
E: Couldn't find any package by regex 'nvidia-bug-report-20190806_1537.log.gz'
E: Unable to locate package nvidia-bug-report-20190807_0919.log.gz
E: Couldn't find any package by glob 'nvidia-bug-report-20190807_0919.log.gz'
E: Couldn't find any package by regex 'nvidia-bug-report-20190807_0919.log.gz'
E: Unable to locate package nvidia-bug-report.log.gz
E: Couldn't find any package by glob 'nvidia-bug-report.log.gz'
E: Couldn't find any package by regex 'nvidia-bug-report.log.gz'
nvidia-driver-430 set on hold.
So, it seems everything is the same :P
Another thing, when i enter Software and Updates > Aditional Drivers it only shows 430, but i think it should show more (390, 396, 410, 415, 418)
I’ve tried re-add the ppa, but everything is the same
Please re-run it in an empty directory or remove the nvidia-bug-reports (rm nvidia-*) beforehand.
I’ve done it, but the 2nd and 3rd outputs are the same. But its strange that it does not remove anything with nvidia-*
sudo apt list --installed | grep nvidia-
libnvidia-cfg1-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
libnvidia-common-430/bionic,bionic,now 430.40-0ubuntu0~gpu18.04.1 all [installed,automatic]
libnvidia-compute-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
libnvidia-decode-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
libnvidia-encode-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
libnvidia-fbc1-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
libnvidia-gl-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
libnvidia-ifr1-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
nvidia-compute-utils-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
nvidia-dkms-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
nvidia-driver-418/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed]
nvidia-driver-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed]
nvidia-kernel-common-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed]
nvidia-kernel-source-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
nvidia-prime/bionic-updates,bionic-updates,now 0.8.8.2 all [installed,automatic]
nvidia-settings/bionic,now 418.56-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
nvidia-utils-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed]
xserver-xorg-video-nvidia-430/bionic,now 430.40-0ubuntu0~gpu18.04.1 amd64 [installed,automatic]
I’m going to try that via tty
sudo apt-mark unhold nvidia-driver-430
Via tty was exactly the same. I’ve found that sudo apt purge nvidia* did not work but sudo apt purge “nvidia*” did work (???)
So i’ve done this:
sudo apt remove “nvidia*”
The following packages were automatically installed and are no longer required:
dkms libnvidia-cfg1-430 libnvidia-common-430 libnvidia-compute-430 libnvidia-compute-430:i386 libnvidia-decode-430 libnvidia-decode-430:i386 libnvidia-encode-430 libnvidia-encode-430:i386 libnvidia-fbc1-430
libnvidia-fbc1-430:i386 libnvidia-gl-430 libnvidia-gl-430:i386 libnvidia-ifr1-430 libnvidia-ifr1-430:i386 libxnvctrl0 pkg-config screen-resolution-extra xserver-xorg-video-nvidia-430
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
nvidia-compute-utils-430 nvidia-dkms-430 nvidia-driver-430 nvidia-kernel-common-430 nvidia-kernel-source-430 nvidia-prime nvidia-settings nvidia-utils-430
0 upgraded, 0 newly installed, 8 to remove and 82 not upgraded.
After this operation, 38,6 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 430644 files and directories currently installed.)
Removing nvidia-driver-430 (430.26-0ubuntu0.18.04.2) ...
Removing nvidia-compute-utils-430 (430.26-0ubuntu0.18.04.2) ...
Removing nvidia-dkms-430 (430.26-0ubuntu0.18.04.2) ...
Removing all DKMS Modules
Done.
INFO:Disable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
update-initramfs: deferring update (trigger activated)
Removing nvidia-kernel-common-430 (430.26-0ubuntu0.18.04.2) ...
Removing nvidia-kernel-source-430 (430.26-0ubuntu0.18.04.2) ...
Removing nvidia-prime (0.8.8.2) ...
Removing nvidia-settings (390.77-0ubuntu0.18.04.1) ...
Removing nvidia-utils-430 (430.26-0ubuntu0.18.04.2) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for initramfs-tools (0.130ubuntu3.8) ...
update-initramfs: Generating /boot/initrd.img-5.2.7-050207-generic
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
sudo apt autoremove
0 upgraded, 0 newly installed, 19 to remove and 82 not upgraded.
After this operation, 464 MB disk space will be freed.
(Reading database ... 430146 files and directories currently installed.)
Removing dkms (2.3-3ubuntu9.5) ...
Removing xserver-xorg-video-nvidia-430 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-cfg1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-ifr1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-gl-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-ifr1-430:i386 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-gl-430:i386 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-common-430 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-encode-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-decode-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-compute-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-encode-430:i386 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-decode-430:i386 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-compute-430:i386 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-fbc1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Removing libnvidia-fbc1-430:i386 (430.26-0ubuntu0.18.04.2) ...
Removing libxnvctrl0:amd64 (390.77-0ubuntu0.18.04.1) ...
Removing pkg-config (0.29.1-0ubuntu2) ...
Removing screen-resolution-extra (0.17.3) ...
Processing triggers for dbus (1.12.2-1ubuntu1.1) ...
The following additional packages will be installed:
libnvidia-fbc1-430:i386 libnvidia-gl-430 libnvidia-gl-430:i386 libnvidia-ifr1-430 libnvidia-ifr1-430:i386 libxnvctrl0 nvidia-compute-utils-430 nvidia-dkms-430 nvidia-driver-430 nvidia-kernel-common-430
nvidia-kernel-source-430 nvidia-prime nvidia-settings nvidia-utils-430 pkg-config screen-resolution-extra xserver-xorg-video-nvidia-430
Suggested packages:
menu
The following NEW packages will be installed:
libnvidia-fbc1-430:i386 libnvidia-gl-430 libnvidia-gl-430:i386 libnvidia-ifr1-430 libnvidia-ifr1-430:i386 libxnvctrl0 nvidia-compute-utils-430 nvidia-dkms-430 nvidia-driver-418 nvidia-driver-430
nvidia-kernel-common-430 nvidia-kernel-source-430 nvidia-prime nvidia-settings nvidia-utils-430 pkg-config screen-resolution-extra xserver-xorg-video-nvidia-430
0 upgraded, 28 newly installed, 0 to remove and 82 not upgraded.
Need to get 6364 B/109 MB of archives.
After this operation, 503 MB of additional disk space will be used.
Get:1 http://pt.archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 nvidia-driver-418 amd64 430.26-0ubuntu0.18.04.2 [6364 B]
Fetched 6364 B in 0s (73,7 kB/s)
Selecting previously unselected package dkms.
(Reading database ... 429948 files and directories currently installed.)
Preparing to unpack .../00-dkms_2.3-3ubuntu9.5_all.deb ...
Unpacking dkms (2.3-3ubuntu9.5) ...
Selecting previously unselected package libnvidia-cfg1-430:amd64.
Preparing to unpack .../01-libnvidia-cfg1-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-cfg1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-common-430.
Preparing to unpack .../02-libnvidia-common-430_430.26-0ubuntu0.18.04.2_all.deb ...
Unpacking libnvidia-common-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-compute-430:i386.
Preparing to unpack .../03-libnvidia-compute-430_430.26-0ubuntu0.18.04.2_i386.deb ...
Unpacking libnvidia-compute-430:i386 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-compute-430:amd64.
Preparing to unpack .../04-libnvidia-compute-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-compute-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-decode-430:amd64.
Preparing to unpack .../05-libnvidia-decode-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-decode-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-decode-430:i386.
Preparing to unpack .../06-libnvidia-decode-430_430.26-0ubuntu0.18.04.2_i386.deb ...
Unpacking libnvidia-decode-430:i386 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-encode-430:i386.
Preparing to unpack .../07-libnvidia-encode-430_430.26-0ubuntu0.18.04.2_i386.deb ...
Unpacking libnvidia-encode-430:i386 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-encode-430:amd64.
Preparing to unpack .../08-libnvidia-encode-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-encode-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-fbc1-430:amd64.
Preparing to unpack .../09-libnvidia-fbc1-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-fbc1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-fbc1-430:i386.
Preparing to unpack .../10-libnvidia-fbc1-430_430.26-0ubuntu0.18.04.2_i386.deb ...
Unpacking libnvidia-fbc1-430:i386 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-gl-430:amd64.
Preparing to unpack .../11-libnvidia-gl-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-gl-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-gl-430:i386.
Preparing to unpack .../12-libnvidia-gl-430_430.26-0ubuntu0.18.04.2_i386.deb ...
Unpacking libnvidia-gl-430:i386 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-ifr1-430:amd64.
Preparing to unpack .../13-libnvidia-ifr1-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking libnvidia-ifr1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libnvidia-ifr1-430:i386.
Preparing to unpack .../14-libnvidia-ifr1-430_430.26-0ubuntu0.18.04.2_i386.deb ...
Unpacking libnvidia-ifr1-430:i386 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package libxnvctrl0:amd64.
Preparing to unpack .../15-libxnvctrl0_390.77-0ubuntu0.18.04.1_amd64.deb ...
Unpacking libxnvctrl0:amd64 (390.77-0ubuntu0.18.04.1) ...
Selecting previously unselected package nvidia-compute-utils-430.
Preparing to unpack .../16-nvidia-compute-utils-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-compute-utils-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-kernel-source-430.
Preparing to unpack .../17-nvidia-kernel-source-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-kernel-source-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-kernel-common-430.
Preparing to unpack .../18-nvidia-kernel-common-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-kernel-common-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-dkms-430.
Preparing to unpack .../19-nvidia-dkms-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-dkms-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-utils-430.
Preparing to unpack .../20-nvidia-utils-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-utils-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package xserver-xorg-video-nvidia-430.
Preparing to unpack .../21-xserver-xorg-video-nvidia-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking xserver-xorg-video-nvidia-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-driver-430.
Preparing to unpack .../22-nvidia-driver-430_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-driver-430 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-driver-418.
Preparing to unpack .../23-nvidia-driver-418_430.26-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-driver-418 (430.26-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-prime.
Preparing to unpack .../24-nvidia-prime_0.8.8.2_all.deb ...
Unpacking nvidia-prime (0.8.8.2) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../25-pkg-config_0.29.1-0ubuntu2_amd64.deb ...
Unpacking pkg-config (0.29.1-0ubuntu2) ...
Selecting previously unselected package screen-resolution-extra.
Preparing to unpack .../26-screen-resolution-extra_0.17.3_all.deb ...
Unpacking screen-resolution-extra (0.17.3) ...
Selecting previously unselected package nvidia-settings.
Preparing to unpack .../27-nvidia-settings_390.77-0ubuntu0.18.04.1_amd64.deb ...
Unpacking nvidia-settings (390.77-0ubuntu0.18.04.1) ...
Setting up nvidia-prime (0.8.8.2) ...
Setting up nvidia-kernel-common-430 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-common-430 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-cfg1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up pkg-config (0.29.1-0ubuntu2) ...
Setting up dkms (2.3-3ubuntu9.5) ...
Setting up libnvidia-compute-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-compute-430:i386 (430.26-0ubuntu0.18.04.2) ...
Setting up nvidia-kernel-source-430 (430.26-0ubuntu0.18.04.2) ...
Setting up screen-resolution-extra (0.17.3) ...
Setting up libnvidia-fbc1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-fbc1-430:i386 (430.26-0ubuntu0.18.04.2) ...
Setting up libxnvctrl0:amd64 (390.77-0ubuntu0.18.04.1) ...
Setting up nvidia-dkms-430 (430.26-0ubuntu0.18.04.2) ...
INFO:Enable nvidia
Loading new nvidia-430.26 DKMS files...
Building for 5.2.7-050207-generic
Building for architecture x86_64
Building initial module for 5.2.7-050207-generic
Secure Boot not enabled on this system.
Done.
nvidia:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.2.7-050207-generic/updates/dkms/
nvidia-modeset.ko:
- Original module
- Installation
nvidia-drm.ko:
- Original module
- Installation
nvidia-uvm.ko:
- Original module
- Installation
depmod...
DKMS: install completed.
Setting up xserver-xorg-video-nvidia-430 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-decode-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-decode-430:i386 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-gl-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-gl-430:i386 (430.26-0ubuntu0.18.04.2) ...
Setting up nvidia-utils-430 (430.26-0ubuntu0.18.04.2) ...
Setting up nvidia-settings (390.77-0ubuntu0.18.04.1) ...
Setting up nvidia-compute-utils-430 (430.26-0ubuntu0.18.04.2) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 122) ...
Adding new group `nvidia-persistenced' (GID 127) ...
Adding new user `nvidia-persistenced' (UID 122) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up libnvidia-encode-430:i386 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-encode-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-ifr1-430:amd64 (430.26-0ubuntu0.18.04.2) ...
Setting up libnvidia-ifr1-430:i386 (430.26-0ubuntu0.18.04.2) ...
Setting up nvidia-driver-430 (430.26-0ubuntu0.18.04.2) ...
Setting up nvidia-driver-418 (430.26-0ubuntu0.18.04.2) ...
But guess what? Everything is the same xD I’m condemned!
does it work if you purge and install by explicit package name, i.e.
sudo apt install nvidia-driver-418_418.56-0ubuntu0
Forget about it, I forgot you’re running kernel 5.2, only driver 430 works with that. Just reinstall the OS.
It does not let me install like that. Here are the possibilites:
nvidia-304 nvidia-352-dev nvidia-compute-utils-430 nvidia-headless-430 nvidia-libopencl1-340-updates nvidia-opencl-icd-352
nvidia-304-dev nvidia-352-updates nvidia-cuda-dev nvidia-headless-no-dkms-390 nvidia-libopencl1-346 nvidia-opencl-icd-352-updates
nvidia-304-updates nvidia-352-updates-dev nvidia-cuda-doc nvidia-headless-no-dkms-410 nvidia-libopencl1-346-updates nvidia-opencl-icd-361
nvidia-304-updates-dev nvidia-361 nvidia-cuda-gdb nvidia-headless-no-dkms-415 nvidia-libopencl1-352 nvidia-opencl-icd-361-updates
nvidia-331 nvidia-361-dev nvidia-cuda-toolkit nvidia-headless-no-dkms-418 nvidia-libopencl1-352-updates nvidia-opencl-icd-367
nvidia-331-dev nvidia-361-updates nvidia-current nvidia-headless-no-dkms-430 nvidia-libopencl1-361 nvidia-opencl-icd-375
nvidia-331-updates nvidia-361-updates-dev nvidia-current-dev nvidia-kernel-common-390 nvidia-libopencl1-361-updates nvidia-opencl-icd-384
nvidia-331-updates-dev nvidia-367 nvidia-dkms-390 nvidia-kernel-common-410 nvidia-libopencl1-367 nvidia-prime
nvidia-331-updates-uvm nvidia-367-dev nvidia-dkms-410 nvidia-kernel-common-415 nvidia-libopencl1-375 nvidia-profiler
nvidia-331-uvm nvidia-375 nvidia-dkms-415 nvidia-kernel-common-418 nvidia-libopencl1-384 nvidia-settings
nvidia-340 nvidia-375-dev nvidia-dkms-418 nvidia-kernel-common-430 nvidia-modprobe nvidia-utils-390
nvidia-340-dev nvidia-384 nvidia-dkms-430 nvidia-kernel-source-390 nvidia-nsight nvidia-utils-410
nvidia-340-updates nvidia-384-dev nvidia-driver-390 nvidia-kernel-source-410 nvidia-opencl-dev nvidia-utils-415
nvidia-340-updates-dev nvidia-cg-dev nvidia-driver-410 nvidia-kernel-source-415 nvidia-opencl-icd-304 nvidia-utils-418
nvidia-340-updates-uvm nvidia-cg-doc nvidia-driver-415 nvidia-kernel-source-418 nvidia-opencl-icd-304-updates nvidia-utils-430
nvidia-340-uvm nvidia-cg-toolkit nvidia-driver-418 nvidia-kernel-source-430 nvidia-opencl-icd-331 nvidia-visual-profiler
nvidia-346 nvidia-common nvidia-driver-430 nvidia-libopencl1-304 nvidia-opencl-icd-331-updates
nvidia-346-dev nvidia-compute-utils-390 nvidia-headless-390 nvidia-libopencl1-304-updates nvidia-opencl-icd-340
nvidia-346-updates nvidia-compute-utils-410 nvidia-headless-410 nvidia-libopencl1-331 nvidia-opencl-icd-340-updates
nvidia-346-updates-dev nvidia-compute-utils-415 nvidia-headless-415 nvidia-libopencl1-331-updates nvidia-opencl-icd-346
nvidia-352 nvidia-compute-utils-418 nvidia-headless-418 nvidia-libopencl1-340 nvidia-opencl-icd-346-updates
Ok :D
Thank you very much for your efforts, i think im going to postprone that a bit, but after i’ve done i come back here to give feedback.
Thanks again!!!
Hi again!
Yep, i’ve reinstalled the OS and everything is fine now :P
One thing i’ve noticed is that the driver present in Software and Drivers is proprietary and not open source as i had before.
So,
- the current driver is the one in the screenshot,
- if i enter Nvidia Settings i do have all settings now (when nvidia is selected, ofc)
- my battery lasts 3~4 hours with nvidia selected.
Thank again for all the help!
Cheers
