Please help me to investigate following strange issue… After several attempts, still getting the same error while trying to flash Jetson Orin Nano dev kit via USB C cable. I suspect it might be because I’m doing this from under the WSL2 (LinuxForWindows). I can see the Jetson Nano USB device from inside WSL2, though.
some of the (probably) relevant places from logs below
from file NV_L4T_FILE_SYSTEM_AND_OS_COMP.log:
Using rootfs directory of: /mnt/d/jetpack_image/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
||||||||||||||||||||||| ERROR |||||||||||||||||||||||
1. The root filesystem, provided with this package,
has to be extracted to this directory:
2. The root filesystem, provided with this package,
has to be extracted with 'sudo' to this directory:
Consult the Development Guide for instructions on
extracting and flashing your device.
12:43:29.264 - Error: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.igor.sh; [error]:
12:43:29.264 - Info: [ Package Install Finished with Error ]
12:43:29.265 - Info: [host] [ 5.65 GB used. Disk Avail: 167.45 GB ]
12:43:29.265 - Info: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 54m36s ]
and from the sdkm-2024-02-23-11-47-54.log
12:43:29.255 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: Using rootfs directory of: /mnt/d/jetpack_image/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
12:43:29.263 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: ||||||||||||||||||||||| ERROR |||||||||||||||||||||||
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: -----------------------------------------------------
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: 1. The root filesystem, provided with this package,
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: has to be extracted to this directory:
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: /mnt/d/jetpack_image/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: 2. The root filesystem, provided with this package,
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: has to be extracted with 'sudo' to this directory:
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: Consult the Development Guide for instructions on
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: extracting and flashing your device.
12:43:29.264 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: |||||||||||||||||||||||||||||||||||||||||||||||||||||
12:43:29.266 - error: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.igor.sh; [error]:
12:43:29.267 - info: Event: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS - error is: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.igor.sh; [error]:
12:43:29.267 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS:
12:43:29.267 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: [ Package Install Finished with Error ]
12:43:29.267 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: [host] [ 5.65 GB used. Disk Avail: 167.45 GB ]
12:43:29.267 - info: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 54m36s ]
12:43:29.267 - error: command error code: 11
12:43:29.267 - info: Event: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS - error code is: 1011
12:43:29.267 - error: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: command terminated with error
12:43:29.267 - info: Event: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS - error is: command terminated with error
12:43:29.270 - info: Event: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS - install ended - failure
12:43:29.271 - error: Session first failure occurred while Installing. Root cause component: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS. Root cause error code: (1011: Failed to execute commands with GenericInstaller)
12:43:29.271 - info: Summary: NV_L4T_FILE_SYSTEM_AND_OS_COMP@JETSON_ORIN_NANO_TARGETS: Installation failed.
12:43:29.272 - info: Event: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_ORIN_NANO_TARGETS - error is: NVIDIA Container Runtime with Docker integration (Beta) Skipped. Due to its dependencies fail to install: File System and OS
12:43:29.272 - info: Component install GA report: Component Install: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP#2.1 - finished failed Error Code: 500. Error: Depends on failed component. Component ID: . PrecheckStatus: None. TargetDeviceImageVersion: #. RetryNumber: 0
12:43:29.277 - info: Event: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_ORIN_NANO_TARGETS - install ended - failure
12:43:29.277 - info: Summary: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_ORIN_NANO_TARGETS: Depends on failed component
12:43:29.277 - info: Event: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_COMP@JETSON_ORIN_NANO_TARGETS - error is: Multimedia API Skipped. Due to its dependencies fail to install: File System and OS
12:43:29.277 - info: Component install GA report: Component Install: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_COMP#36.2 - finished failed Error Code: 500. Error: Depends on failed component. Component ID: . PrecheckStatus: None. TargetDeviceImageVersion: #. RetryNumber: 0
