I use the SDK manager install JetPack4.2,but there is no file named jetson_clocks.sh,then i download a file put in /home ,when i use sudo sh jeson_clocks.sh,there is
Binary file /proc.device-tree/compatible matches
Can’t access Fan!
Is anyone had meet the problem. Please help me!
You may check this.
Thank you very much! I had fixed it !
hello @1091574181,
Could you please tell me how to fix the “Can’t access Fan!” when run /usr/bin/jetson_clocks.
Thank you.
