I got a problem with FAN on my custom base board. But it works fine on the developed board.
It is nothing on the pwm output pin.The error is shown below:
nvidia@tegra-ubuntu:~$ sudo ./jetson_clocks.sh
[sudo] password for nvidia:
Can't access Fan!
What’s the different of your custom carrier board compared with origin carrier board? Maybe that’s caused by device tree issue, bot really sure, but you can refer to [url]https://elinux.org/Jetson/TX2_DTB[/url].
Besides, could you try JetPack3.1/R28.1 to confirm again?
I had a SD card installed when installing Jetpack, some how the Jeston was failing to read from the debug file system. Re-flashing the Jetson without the SD allowed the fan to start. Hope this helps, I couldn’t find a good answer but I had this with Two Jetsons and this seem to fix them.
