Can't compile cuda fortran code on Jetson nano
I wanted to compile cuda fortran code on Jetson nano but I got a error as below.
$ nvfortran -Mcuda cuforTest.f90
/usr/bin/ld: cannot find -lcudafor_102
pgacclnk: child process exit status 1: /usr/bin/ld
Looking for the cause, I found that although the HPC SDK for Linux x86_64 includes the library for cuda 10.2,
it does not include it for arm. Is this related to this error?
I have installed the SDK which includes 3 versions for both x86_64 and arm and checked β€œ/opt/nvidia/hpc_sdk/(target)/22.7/compilers/lib”.
Thank you.
Hi _seed,
Correct. ARM requires CUDA 11 or above. Please see our release notes for supported platforms and configurations:
-Mat
Dear Mat,
Thank you very much for reply.
I understood that CUDA 11 is required for arm architecture.
-_seed
