I just started using TX1 and wanted to use my laptop to program using CUDA C/C++ code, then run it on TX1. However, there is a very serious problem I’m facing is that I could not find TX1 when I’m building the project. The error which I’m encountering is like this
Failed to connect sshd on "192.168.0.113:22"
and
Unable to establish shell connection to "TX1"
But the first time I was trying to connect was successful. And two days later when I wanted to use it, it didn’t work any longer.
So what should I do? Thanks for any help.
