Can't create New Partition NVIDIA AGX Orin
DRIVE OS Version: Provide DRIVE OS version. 6.0.8.1
Issue Description: We want to create a new partition that is visible in the Linux user space. I am updating below configuration file from the SDK files in the docker container:
/drive/drive-foundation/platform-config/hardware/nvidia/platform/t23x/automotive/pct/drive_av/linux/global_storage.cfg
For test, I just modified the DEMO_PARTITION 10 G into 5G + 5G two partitions.
Able to bind partitions and flash the image successfully. But, Orin doesn’t boot after flashing.
Error reported on minicom /dev/ttyACM0:
IVM 64 has multiple associated vblk devices
VSC configuration parsing failed
Upon reverting change partition change, Orin is booting normally.
Updated global_storage.cfg:
#ifdef ENABLE_DEMO_PARTITION
[partition]
name=gos0-demo-ufs
allocation_policy=sequential
size=0x280000000
partition_attribute=<GID_GUEST0_VM+1>
virtual_storage_ivc_ch=0x801640F8
ufs_stream_id=TEGRA_SID_NISO0_UFS_14
/* — First Half (5GB) — */
[partition]
name=gos0-demo-ufs-part1
size=0x140000000
/* — Second Half (5GB) — */
[partition]
name=gos0-demo-ufs-part2
size=0x140000000
virtual_storage_ivc_ch=0x801640F9
endif
There is already a similar ticket which still pending on NVIDIA forum. This ticket is like a follow to it. Please provide your inputs to support creating a new partition.
Also, please let me know how to this partitioning on NVIDIA AGX Thor Target.
Dear @dasari.sampath ,
modifying the partition is outside the forum support scope. May I know why you are looking to add new partition? Creating a new folder does not help your use case?
Hi Siva,
I am looking for this capability to store project specific in a dedicated partition. Please direct me to get more information to achieve this creating a new partition on both Orin & Thor.
I was suggesting to /dev/vblkdev2 partition to store information. It does not help your case?
nvidia@tegra-ubuntu:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/vblkdev0    26G   18G  7.1G  71% /
none             15G     0   15G   0% /dev
tmpfs            15G   13M   15G   1% /dev/shm
tmpfs           2.9G  1.7M  2.9G   1% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs            15G     0   15G   0% /sys/fs/cgroup
tmpfs            15G     0   15G   0% /mnt
/dev/vblkdev1   220M  1.1M  201M   1% /mnt/persistent/metadata
/dev/vblkdev2   116G   91G   19G  84% /mnt/persistent/data
overlay         220M  1.1M  201M   1% /etc
overlay         116G   91G   19G  84% /home
tmpfs           2.9G   12K  2.9G   1% /run/user/110
tmpfs           2.9G  4.0K  2.9G   1% /run/user/1000
Could you please provide any update for this topic?
