Partitions on Onrin
Software Version
DRIVE OS 6.0.4 SDK
DRIVE OS 6.0.4 (rev. 1)
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10426
other (1.8.4.10431)
Host Machine Version
other
I have couple questions regarding to my Drive Orin storage:
Q1:
I see that my mounted partition is 32GB, however the m2 drive that installed is 256GB. I see that there are other partitions.
What are they used for? Is there another “mode” I can load the system?
Q2:
I want to upgrade to m2 capacity, however when I switch to a fresh drive and flash using sdkmanager, it fails at the end of the installation.
In logs I see that there was an access to tmp_global_storage_sub2.cfg, where I see couple different partition names, therefore I guess if I install a new drive that should be configured manually.
How do I configure a new m2 for flashing?
Please, see logs attached.
Thanks,
Nikolay
SDKM_logs_DRIVE_OS_6.0.4_SDK_(rev._1)_Linux_for_DRIVE_AGX_Orin_DevKits_2022-11-02_20-46-46.zip (1.9 MB)
Sorry for the late response, is this still an issue to support? Thanks
Dear @NikolayChernuha,
Q1. /dev/vblkdev3 is UFS . Please see
How to mount all areas of eMMC and UFS under Linux - #5 by SivaRamaKrishnaNV if it helps.
Q2. Looks similar to Drive os flashing on different drive and will be followed in that topic.
