I am facing a few issues with nvidia 550 driver and I want to downgrade to 525.
Running Ubuntu 22.04.4 LTS (5.15.0-56-generic)
My issues are as follows
- Debian package manager just install nvidia 550 regardless of the package I choose.
ubuntu-driverthink drivers are already installed if I try to install a specific version.ubuntu-driverautoinstall/install just install 550, whihc is correct but I don’t want this driver.
I have tried purge all nvidia packages from my system as per the solution in post but it doesn’t help.
Here is what happening when I use apt-get to install nvidia-driver-525. Once the installation completes nvidia-smi shows that it’s using nvidia 550 not 525.
sudo apt-get -s install nvidia-driver-525
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
libnvidia-cfg1-550 libnvidia-common-550 libnvidia-compute-550 libnvidia-decode-550 libnvidia-egl-wayland1 libnvidia-encode-550 libnvidia-extra-550 libnvidia-fbc1-550 libnvidia-gl-550
nvidia-compute-utils-550 nvidia-dkms-550 nvidia-driver-550 nvidia-firmware-550-550.54.14 nvidia-kernel-common-550 nvidia-kernel-source-550 nvidia-settings nvidia-utils-550 screen-resolution-extra
xserver-xorg-video-nvidia-550
Recommended packages:
libnvidia-compute-550:i386 libnvidia-decode-550:i386 libnvidia-encode-550:i386 libnvidia-fbc1-550:i386 libnvidia-gl-550:i386
The following NEW packages will be installed:
nvidia-compute-utils-550 nvidia-dkms-550 nvidia-driver-525 nvidia-driver-550 nvidia-firmware-550-550.54.14 nvidia-kernel-common-550 nvidia-kernel-source-550 nvidia-settings nvidia-utils-550
screen-resolution-extra xserver-xorg-video-nvidia-550
0 upgraded, 20 newly installed, 0 to remove and 0 not upgraded.
Inst libnvidia-cfg1-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst libnvidia-common-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [all])
Inst libnvidia-compute-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst libnvidia-decode-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst libnvidia-egl-wayland1 (1:1.1.9-1.1 Ubuntu:22.04/jammy [amd64])
Inst libnvidia-encode-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst libnvidia-extra-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst libnvidia-fbc1-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst libnvidia-gl-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-compute-utils-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-kernel-source-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-kernel-common-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-firmware-550-550.54.14 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-dkms-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-utils-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst xserver-xorg-video-nvidia-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-driver-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst nvidia-driver-525 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Inst screen-resolution-extra (0.18.2 Ubuntu:22.04/jammy [all])
Inst nvidia-settings (510.47.03-0ubuntu1 Ubuntu:22.04/jammy [amd64])
Conf libnvidia-cfg1-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf libnvidia-common-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [all])
Conf libnvidia-compute-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf libnvidia-decode-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf libnvidia-egl-wayland1 (1:1.1.9-1.1 Ubuntu:22.04/jammy [amd64])
Conf libnvidia-encode-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf libnvidia-extra-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf libnvidia-fbc1-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf libnvidia-gl-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-compute-utils-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-kernel-source-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-kernel-common-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-firmware-550-550.54.14 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-dkms-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-utils-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf xserver-xorg-video-nvidia-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-driver-550 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf nvidia-driver-525 (550.54.14-1pop0~1709151545~22.04~c91e06a~dev System76 Stable PPA:22.04/jammy [amd64])
Conf screen-resolution-extra (0.18.2 Ubuntu:22.04/jammy [all])
Conf nvidia-settings (510.47.03-0ubuntu1 Ubuntu:22.04/jammy [amd64])
Here is what happening when I use apt-get to install nvidia-driver-525-open.
sudo apt-get -s install nvidia-driver-525-open
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-driver-535-open : Depends: libnvidia-gl-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: libnvidia-compute-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: libnvidia-extra-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: nvidia-compute-utils-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: libnvidia-decode-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: libnvidia-encode-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: nvidia-utils-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: xserver-xorg-video-nvidia-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: libnvidia-cfg1-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Depends: libnvidia-fbc1-535 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not going to be installed
Recommends: nvidia-settings but it is not going to be installed
Recommends: libnvidia-compute-535:i386 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not installable
Recommends: libnvidia-decode-535:i386 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not installable
Recommends: libnvidia-encode-535:i386 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not installable
Recommends: libnvidia-fbc1-535:i386 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not installable
Recommends: libnvidia-gl-535:i386 (= 535.113.01-1pop0~1695753528~22.04~0561f9e~dev) but it is not installable
E: Unable to correct problems, you have held broken packages.
