Good day!
Been trying to reflash Jetson Agx Orin Jetpack using SDK Manager. The process returns with error, cheking the command terminal and filtering by summary the following erros are launched by the system
11:03:49 SUMMARY: File System and OS - target_image: First Error: Installation failed.
11:03:49 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
11:03:49 SUMMARY: Multimedia API - target: Depends on failed component
11:03:49 SUMMARY: TensorRT on Target - target: Depends on failed component
11:03:49 SUMMARY: TensorRT Runtime - target: Depends on failed component
11:03:49 SUMMARY: VPI on Target - target: Depends on failed component
11:03:49 SUMMARY: VPI Runtime - target: Depends on failed component
11:03:49 SUMMARY: CuPVA Runtime - target: Depends on failed component
11:03:49 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
11:03:49 SUMMARY: CUDA Runtime - target: Depends on failed component
11:03:49 SUMMARY: cuDNN on Target - target: Depends on failed component
11:03:49 SUMMARY: CuDNN Runtime - target: Depends on failed component
11:03:49 SUMMARY: OpenCV - target: Depends on failed component
11:03:49 SUMMARY: OpenCV Runtime - target: Depends on failed component
11:03:49 SUMMARY: DateTime Target Setup - target: Depends on failed component
11:03:49 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
I append the whole exported log zip that sdk manager gives
Thanks for the help
SDKM_logs_JetPack_5.1_Linux_for_Jetson_AGX_Orin_modules_2023-02-01_10-59-54.zip (69.9 KB)
