Hi guys,
I’ve been having troubles installing drivers in the aforementioned setup. I’ve tried something like 10 different tutorials, tried drivers from the ppa and nvidia website, tried autoinstall of recommended drivers. Nothing works for me. I tried to go here
https://devtalk.nvidia.com/default/topic/533434/linux/current-graphics-driver-releases/, then to section Legacy releases for GF1xx “Fermi” GPUs - version 390.xx - did not work. I have no idea what to do next.
During 390.xx,410,415 installations I was having the following issue: DKMS modules were built just fine, but at the very end of the installation, I get this error message: unable to load the nvidia-drm kernel module. It suggests to go and check /var/log/ for more info. But that log does not contain anything apart the messages of successfully finished installations steps and the final message that unable to load the nvidia-drm kernel module.
After every installation the resolution of my display is 1024x768, whereas for normally working drivers it should be 2560x1440.
Also, I should mention that the Ubuntu installation is completely fresh.
Here is the output of some commands that I think might be minimally useful for troubleshooting the problem.
sudo lshw -c display
*-display
description: VGA compatible controller
product: GP104 [GeForce GTX 1070]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:127 memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:c0000-dffff
After any driver installation attempts line
becomes
configuration: latency=0
and
sudo ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001B81sv00001043sd00008597bc03sc00i00
vendor : NVIDIA Corporation
model : GP104 [GeForce GTX 1070]
driver : nvidia-driver-390 - distro non-free recommended
driver : xserver-xorg-video-nouveau - distro free builtin
Please, let me know if I must provide more info to make it clearer.
Thank you.
