I have configured Xavier from OEM-config as per this post and it was working fine with DeepStream 5. It has latest Jetpack 4.4. Yesterday, I tried to setup DeepStream Test5 App to test with Azure IoT and installed iotedge package as per the README in deepstream-test5 C example. I got issues about iotedge certificate, so I re-installed it and then it worked fine. Now, when I rebooted device, it’s not showing GUI after message ‘Started Update UTMP about System Runlevel Changes’.
I can still access it from SSH and run commands, GUI doesn’t show up after connecting to monitor.
After first boot,sudo apt-get update gives below errors:
Ign:1 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Ign:2 https://packages.microsoft.com/ubuntu/18.04/multiarch/prod bionic InRelease
Ign:3 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Err:5 https://repo.download.nvidia.com/jetson/common r32.4 Release
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: XX.XX.XX.XX 443]
Err:6 https://packages.microsoft.com/ubuntu/18.04/multiarch/prod bionic Release
Err:7 https://repo.download.nvidia.com/jetson/t194 r32.4 Release
Hit:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Hit:9 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Hit:10 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Reading package lists... Done
E: The repository 'https://repo.download.nvidia.com/jetson/common r32.4 Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://packages.microsoft.com/ubuntu/18.04/multiarch/prod bionic Release' no longer has a Release file.
E: The repository 'https://repo.download.nvidia.com/jetson/t194 r32.4 Release' no longer has a Release file.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease is not valid yet (invalid for another 88d 7h 36min 32s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease is not valid yet (invalid for another 998d 15h 27min 14s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease is not valid yet (invalid for another 998d 15h 28min 5s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease is not valid yet (invalid for another 998d 15h 26min 32s). Updates for this repository will not be applied.
After every reboot, the system date is : Sun Jan 28 09:24:03 PST 2018, no matter whatever I set before reboot.
If I set it to current PDT time and the ‘sudo apt-get update’ command worked fine.
But still the issue related to GUI is same.
The output of sha1sum -c /etc/nv_tegra_release is:
sha1sum: /etc/nv_tegra_release: no properly formatted SHA1 checksum lines found
I tried to connect from USB C-port and sudo picocom -b 115200 /dev/ttyACM0 to get logs, but asks for username and password, after which it shows normal terminal prompt.
