Xavier NX won’t boot to GUI
JP4.6
emmc:16G
The problem I’m having is that the GUI doesn’t load.You can ssh.
This problem only appears in the latest batch, and does not appear in the earlier version. At present, it is suspected that the problem is caused by the different batch
如下图,会卡在此界面。核心模组最新批次才出现此问题,早期的模组不会出现,目前怀疑批次不同所导致的。
log as follows:
Feb 20 16:10:26 lcfc-desktop kernel: [    1.997683] tegradc 15200000.nvdisplay: DT parsed successfully
Feb 20 16:10:26 lcfc-desktop kernel: [    1.997788] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
Feb 20 16:10:26 lcfc-desktop kernel: [    2.004921] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
Feb 20 16:10:26 lcfc-desktop kernel: [    2.005024] tegradc 15200000.nvdisplay: failed to register ihub bw client
Feb 20 16:10:26 lcfc-desktop kernel: [    2.005443] tegradc: probe of 15200000.nvdisplay failed with error -7
Feb 20 16:10:26 lcfc-desktop kernel: [    2.006091] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor
Feb 20 16:10:26 lcfc-desktop kernel: [    2.006180] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
Feb 20 16:10:26 lcfc-desktop kernel: [    2.006456] tegradc 15210000.nvdisplay: DT parsed successfully
Feb 20 16:10:26 lcfc-desktop kernel: [    2.006542] tegradc 15210000.nvdisplay: Display dc.ffffff800bdd0000 registered with id=0
Feb 20 16:10:26 lcfc-desktop kernel: [    2.007834] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
Feb 20 16:10:26 lcfc-desktop kernel: [    2.007898] tegradc 15210000.nvdisplay: failed to register ihub bw client
Feb 20 16:10:26 lcfc-desktop kernel: [    2.008178] tegradc: probe of 15210000.nvdisplay failed with error -7
log.tar.gz (3.9 MB)
通常這種新module搭上舊release branch的問題就是module PCN update.
下面網頁上有PCN overlay. 請確認你的module需要的overlay patch有沒有在上面
这是因为硬件变更导致patch吗
是的. module裡面的DRAM換料會需要一起更換config.
沒辦法用以前同一套memory config
