Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I am currently using pegasus xavier and moved the unit from QNX to Linux 5.2.6 release and i see that the display is not functional. I made sure to force write wipe persistent partitions. when i try to enable display/gui by installing gdm3 or ubuntu unity desktop I see the following error
vidia@tegra-ubuntu:~$ sudo apt install gdm3
[sudo] password for nvidia:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
gdm3 : Depends: libcanberra-gtk3-0 (>= 0.25) but it is not going to be installed
Depends: libgtk-3-0 (>= 3.0.0) but it is not going to be installed
Depends: gnome-session-bin (>= 3.10) but it is not going to be installed
Depends: gnome-settings-daemon (>= 3.24) but it is not going to be installed
Depends: gnome-shell (>= 3.19.92) but it is not going to be installed
Depends: librsvg2-common but it is not going to be installed
Depends: libglib2.0-bin (>= 2.35.0) but it is not going to be installed
Recommends: zenity but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
nvidia@tegra-ubuntu:~$
I did sudo apt-get update , before issuing this command.
How can i check if Xavier B is working right ? Can you provide me input on what is the network path between the 2 ?
Yes the access is via ssh connection. If i try to update some other dependent packages i am able to update. Also i am able to send driveworks tar file over network to the board. . So network is not an issue at all
