Error trying to connect monitor
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
After flashing and installing ubuntu desktop following this instructions: Install DRIVE with SDK Manager :: DRIVE Platform Installation Guide with NVIDIA SDK Manager
I’m still unable to see anything on the monitor, but I get this message in the terminal when the pegasus reboots, and every time i disconnect and connect the monitor.
[  OK  ] Stopped Light Display Manager.
         Starting Light Display Manager...
[  OK  ] Started Light Display Manager.
��verify_rate_range: FMON_NVDISPLAYHUB: rate 2781250 below min 18750000
fmon_update_config: FMON_NVDISPLAYHUB: detected fault 0x4000
��[  OK  ] Started Session c2 of user lightdm.
��[  OK  ] Stopped Light Display Manager.
**��verify_rate_range: FMON_NVDISPLAYHUB: rate 2781250 below min 18750000**
**fmon_update_config: FMON_NVDISPLAYHUB: detected fault 0x4000**
**verify_rate_range: FMON_NVDISPLAYHUB: rate 2781250 below min 18750000**
What’s the meaning of this error and how to fix it?
Dear @jber4282,
May I know the monitor details? Is the same monitor has no issue on DRIVE OS 5.2.0
Hi @SivaRamaKrishnaNV
It’s a dell monitor model 1908fp, yes no issues with Drive OS 5.2.0
Dear @jber4282,
Could you confirm If you have followed the steps in https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/Interfaces/sys_components_file_ubuntu.html#wwpID0E0FB0HA
Also, is it possible to try with another monitor. Please check the discussion on No Monitor Display for DriveOS 5.2.6.0 if it helps.
I presume that this document is outdated as the queries are different. I have flashed the pegasus to have a clean start. I have attached the full log while trying to install GUI on the target, I can see some errors related to the network configuration (which is different from the standard network manager)
Network manager error (545.5 KB)
To pass the last error I remove avahi-daemon
sudo apt-get remove avahi-daemon
Then I’m able to see the installation succeed:
nvidia@tegra-ubuntu:~$ sudo apt-get install gdm3 ubuntu-unity-desktop
Reading package lists... Done
Building dependency tree
Reading state information... Done
ubuntu-unity-desktop is already the newest version (0.1).
gdm3 is already the newest version (3.28.3-0ubuntu18.04.6).
The following packages were automatically installed and are no longer required:
  bind9-host geoip-database libavahi-core7 libbind9-160 libdns1100 libgeoip1
  libisc169 libisccc160 libisccfg160 liblwres160
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 113 not upgraded.
I’ve also set the AutomaticLoginEnable to true.
![image|258x57](upload://624DJbNrPXhMrG6lsYZEk5AEXCR.png
After rebooting I’m unable to see anything on the screen yet, but I can see the following messages:
tegra-ubuntu login: [   35.141401] bash[1309]: Switch did not repospond to MAC 1
[   35.144440] bash[1309]: Get firmware version will be attempted using 02-00-01
[   45.309693] bash[1309]: Unable to get the current switch firmware version
[   45.310280] bash[1309]: Please also check the ethernet interface provided.
[   45.310737] bash[1309]: Current ethernet interface used is : eth0.200
[   45.311096] bash[1309]: Try running with sudo if not already
[   45.311451] bash[1309]: Could not get the current firware version.
[   45.311809] bash[1309]: Updation failed
[   45.312700] bash[1309]: ----------------------- Error log start -------------
[   45.313992] bash[1309]: /lib/firmware/marvell_ethernet//tools/linux/prebuilt0
[   45.314611] bash[1309]: Marvell 88Q5050 Image Download Tool v0.00.0014 (loca)
[   45.315094] bash[1309]: Result = 0
[   45.315355] bash[1309]: Start: 5580, current: 10006581, diff: 10001001, diff1
[   45.315928] bash[1309]: Timeout 10000 elapsed, RX tries: 5560141
[   45.316555] bash[1309]: TIMEOUT!
[   45.316952] bash[1309]: Failed to Get the response for firmware version get .
[   45.317336] bash[1309]: GetFwVersion failed with error:9
[   45.317668] bash[1309]: Image Download Tool exiting with result 2.
[   45.318441] bash[1309]: /lib/firmware/marvell_ethernet//tools/linux/prebuilt0
[   45.318844] bash[1309]: Marvell 88Q5050 Image Download Tool v0.00.0014 (loca)
[   45.319207] bash[1309]: Result = 0
[   45.319527] bash[1309]: Start: 5008, current: 10006009, diff: 10001001, diff1
[   45.319893] bash[1309]: Timeout 10000 elapsed, RX tries: 5594357
[   45.320257] bash[1309]: TIMEOUT!
[   45.320567] bash[1309]: Failed to Get the response for firmware version get .
[   45.321034] bash[1309]: GetFwVersion failed with error:9
[   45.321289] bash[1309]: Image Download Tool exiting with result 2.
[   45.321997] bash[1309]: ----------------------- Error log end ---------------
[   45.322641] bash[1309]: Failed to update the Marvell switch firmware.. Scrip1
which seems to be a network issue ? below the log after rebooting
reboot (95.3 KB)
I have followed the suggested link but still I’m unable to see anything on the screen.
Dear @jber4282,
This is strange. Is the flashing successful? Is it possible to check re-flashing and check installing GUI as given Error trying to connect monitor - #7 by SivaRamaKrishnaNV . If it does not fix, Please attach the fresh logs to file bug.
I re-flashed the pegasus successfully, here the logs:
last_log_14_sept.zip (389.4 KB)
In this query:
I left it as it was (No), keeping the current version as suggested in the guide. For the rest of the queries I also kept the current versions.
The rest of the GUI installation process happened just as described before. Logs below:
nvidia_gui_installation (513.3 KB)
The monitor doesn’t have any signal.
Dear @jber4282,
Could you share the Aurix FW version?
Here it is:
Just an update: I re-flashed the pegasus downgrading it to the Drive OS 5.2.0; after installing the GUI, everything works, and I’m able to see the screen.
Then, re-flash it again with Drive OS 5.2.6 and follow all the instructions without any success the Switch did not resposnd to MAC 1 remains after rebooting and the monitor has no signal.
Dear @jber4282,
Thanks for the update. It looks like issue could be with few monitors. I don’t think switch issue has any connection to display
I am checking internally on switch issue. Do you see gdm is running?
This is the output:
nvidia@tegra-ubuntu:~$ systemctl status display-manager
��● gdm.service - GNOME Display Manager
   Loaded: loaded (/lib/systemd/system/gdm.service; static; vendor preset: enabl
   Active: active (running) since Thu 2021-09-16 16:40:04 AEST; 3h 7min ago
  Process: 1169 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status
 Main PID: 1192 (gdm3)
    Tasks: 4 (limit: 4915)
   CGroup: /system.slice/gdm.service
           ��└��─1192 /usr/sbin/gdm3
Sep 16 19:48:00 tegra-ubuntu gdm3[1192]: GdmDisplay: display lasted 0.491382 sec
Sep 16 19:48:01 tegra-ubuntu gdm3[1192]: Child process -8287 was already dead.
Sep 16 19:48:01 tegra-ubuntu gdm3[1192]: Child process 8269 was already dead.
Sep 16 19:48:01 tegra-ubuntu gdm3[1192]: Unable to kill session worker process
Sep 16 19:48:01 tegra-ubuntu gdm-launch-environment][8306]: pam_unix(gdm-launch-
Sep 16 19:48:01 tegra-ubuntu gdm3[1192]: Child process -8324 was already dead.
Sep 16 19:48:01 tegra-ubuntu gdm3[1192]: Child process 8306 was already dead.
Sep 16 19:48:01 tegra-ubuntu gdm-launch-environment][8339]: pam_unix(gdm-launch-
