Can't select Jetpack version in SDK manager for Jetson AGX Xaviour
Hi, I have hooked up my Jetson AGX Xaviour with my host Linux PC. My carrier board is connected with the Ethernet and is in force recovery mode. The SDK manager on my host is detecting the board but I cannot select any of the jetpack versions from the drop down. Is someone familiar with this issue?
Thanks in advance :')
What version of Ubuntu is running on the host PC? Which L4T or JetPack version are you wanting to flash? Both the model of Jetson (Xavier in this case) and the release version being flashed limit the host Ubuntu version which works (at least in the GUI). It is possible that the intersection of target model and L4T release being flashed (JetPack is a front end to the flash software, L4T is Ubuntu plus NVIDIA drivers, and this is what actually gets flashed) are incompatible (in which case you’d see the releases grayed out).
