I’m wondering if there is a way to save images in RAW and ISP processed images simultaneously.
I know that libargus can capture raw or ISP processed images but I’m not sure if it is possible to get both simultaneously.
The use case will be rendering the ISP processed images in real time but save the raw for further processing. Thanks!
Yes, it’s supported.
You can reference to gstVideoEncode MMAPI sample code to create two output stream one for preview another for RAW.
Got it.
Am I correct that multiStream argus sample code is also an example? Thanks!
system
closed
#8
