I shortened the CBoot time from 13 sec to 2.274 sec by following operations:
- disable all drivers i don’t need
- disable USB_BOOT
- close all logs out through uart
- close the boot chosen
- close the shell
I would like to further shorten the time of CBoot but i don’t know how to do it.
Furthermore, i find the CBoot starts at 1.113 sec, so what is the program before 1.113 sec and how can I shorten it? for example, how can i turn off its log_out.
[0000.066] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.107] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 49000
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
[0000.142] I> Boot-device: QSPI
[0000.145] I> Boot-device: QSPI
[0000.148] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.167] I> ECC region[0]: Start:0x0, End:0x0
[0000.171] I> ECC region[1]: Start:0x0, End:0x0
[0000.175] I> ECC region[2]: Start:0x0, End:0x0
[0000.179] I> ECC region[3]: Start:0x0, End:0x0
[0000.183] I> ECC region[4]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.193] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.202] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.207] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.212] E> FAILED: Thermal config
[0000.219] E> FAILED: MEMIO rail config
[0000.229] I> Boot-device: QSPI
[0000.232] I> Qspi flash params source = mb1bct
[0000.241] I> Qspi flash params source = mb1bct
[0000.253] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.328] I> Qspi flash params source = mb1bct
[0000.357] I> Qspi flash params source = mb1bct
[0000.369] I> MB1 done
[0000.790] I> sdmmc DDR50 mode
[0000.792] I> sdmmc-3 params source = safe params
[0000.798] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.800] W> Cannot find any partition table for 00000003
[0000.804] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.805] W> No valid slot number is found in scratch register
[0000.805] W> Return default slot: _a
[0000.806] I> Active Boot chain : 0
[0000.807] I> parsing oem signed section of bpmp-fw header done
[0000.808] I> bpmp-fw binary init read from storage
[0000.812] I> oem authentication of bpmp-fw header done
[0000.826] I> bpmp-fw binary done read from storage
[0000.826] I> bpmp-fw: Authentication init Done
[0000.827] I> parsing oem signed section of cpubl header done
[0000.831] I> cpubl binary init read from storage
[0000.835] I> bpmp-fw: Authentication Finalize Done
[0000.840] I> oem authentication of cpubl header done
[0000.845] I> cpubl binary done read from storage
[0000.849] I> cpubl: Authentication init Done
[0000.854] I> parsing oem signed section of rce header done
[0000.859] I> rce binary init read from storage
[0000.863] I> Relocating BR-BCT
[0000.866] I> cpubl: Authentication Finalize Done
[0000.871] I> oem authentication of rce header done
[0000.875] I> rce binary done read from storage
[0000.879] I> rce: Authentication init Done
[0000.884] I> parsing oem signed section of ape header done
[0000.889] I> ape binary init read from storage
[0000.893] I> rce: Authentication Finalize Done
[0000.897] I> oem authentication of ape header done
[0000.902] I> ape binary done read from storage
[0000.906] I> ape: Authentication init Done
[0000.911] I> parsing oem signed section of tos header done
[0000.916] I> tos binary init read from storage
[0000.920] I> ape: Authentication Finalize Done
[0000.925] I> oem authentication of tos header done
[0000.931] I> tos binary done read from storage
[0000.933] I> tos: Authentication init Done
[0000.937] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.943] I> bpmp-fw-dtb binary init read from storage
[0000.948] I> tos: Authentication Finalize Done
[0000.954] I> oem authentication of bpmp-fw-dtb header done
[0000.958] I> bpmp-fw-dtb binary done read from storage
[0000.962] I> bpmp-fw-dtb: Authentication init Done
[0000.968] I> parsing oem signed section of cpubl-dtb header done
[0000.973] I> cpubl-dtb binary init read from storage
[0000.978] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.035] I> oem authentication of cpubl-dtb header done
[0001.036] I> cpubl-dtb binary done read from storage
[0001.037] I> cpubl-dtb: Authentication init Done
[0001.038] I> parsing oem signed section of eks header done
[0001.038] I> eks binary init read from storage
[0001.039] I> cpubl-dtb: Authentication Finalize Done
[0001.040] I> oem authentication of eks header done
[0001.044] I> eks binary done read from storage
[0001.048] I> eks: Authentication init Done
[0001.052] I> eks: Authentication Finalize Done
[0001.056] I> EKB detected (length: 0x410) @ VA:0x52714400
NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 14:42:47, Jan 15 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
?鈓rq initialized
[0001.398] initializing heap
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] starting app kernel_boot_app
[0002.274] C> Kernel EP: 0x80080000, DTB: 0x90000000, start time: 1113
