Hi, super noob here,
just working through the initial headless first boot.
having some trouble getting access to the nano from my win 10 pc,
in device manager i am finding that on the other devices tab, the CDC ECM has a driver error, it appears that there is a clash with the usb / ethernet protocol which appears to be preventing me from accessing 192.168.55.1:8888
anyone have any ideas where i can get the drivers for windows to sort this?
Not much help, except to say you’re not alone - I too, a Jetson Nano noob, am having exactly the same problem!
Upon connecting the MicroUSB I do see in the Windows Explorer a new entry called “L4T-README” and that opens successfully with several README files. But like @brendan4418m I cannot access 192.168.55. In a Windows CMD window I cannot ping 192.168.55.1
After poking through the support forum I found the problem.
I downloaded the wrong SD image. As best I can tell, there is a specific Nano Ubuntu image for the course, dlinano_v1-0-0_image_20GB that enables the JupyterLab window at 192.168.55.1:8888.
I earlier had installed the “Jetson Nano Developer Kit SD Card Image” from the startup pages. It runs fine, but does not open up 192.168.1:8888 to the JupyterLab.
Am I the only other person also having this issue? All online searches point to this thread. I’ve tried it on multiple windows 10 machines and the CDC ECM driver is not found by windows? Is there a place to download this driver on Nvidia’s website? From what I can tell, this is not included with windows. Thanks!
I did have the issue mentioned above. And like others, noticed the missing ECM driver that thought that must be the problem.
But it wasn’t.
The problem was I was running the wrong Jetson Nano image.
I was running the image the “Jetson Nano Developer Kit SD Card”. Made sense and booted up just fine. But I couldn’t log into the 192.168.55.1:8888 port and had the ECM driver issue.
Once I installed the correct image for the course, the DLI Jetson Nano image I was able to log into the Jupyter Lab and start working through the course material.
I used the correct image, I could connect to JupiterLab logon page by 192.168.55.1:8888, but the Launcher did not appear on my Windows7 PC.
The Launcher appeared on the Windows10 PC.
First, I thought this was due to no CDC serial and ECM drivers on Windos7, but the device manager of Windos10 says CDC ECM driver is not installed also.
How can I run JupiterLab on my Windows7 PC?
