Hello.
The Issue is that nvme is above the internal emmc in the boot priority.
So system sometimes tried to boot from nvme, but we don’t want to boot from nvme - we use it simply as storage.
What I tried:
- Change boot-order in CBoot console - works fine, but only one-time;
- Edit bootloader/cbo.dts, compile it into .dtb and write it via:
sudo ./flash.sh -k CPUBL-CFG jetson-xavier mmcblk0p1
but it fails with error:
[ 6.1848 ] Sending BCTs
[ 6.1868 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 6.1879 ] Applet version 01.00.0000
[ 6.2595 ] Sending bct_bootrom
[ 6.2596 ] […] 100%
[ 6.2607 ] Sending bct_mb1
[ 6.2657 ] […] 100%
[ 6.2692 ] Sending bct_mem
[ 6.3263 ] […] 100%
[ 6.4440 ]
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed to flash/read t186ref.
Simple flashing worked fine.
Could you help me please?
Used links:
Thanks for response!
I tried it with the default cbo.dts and got this eror:
[ 6.2596 ] […] 100%
[ 6.2657 ] […] 100%
[ 6.3263 ] […] 100%
[ 6.4440 ]
Am I using a proper command?
Also, I use custom dts based on xavier nx devkit, can this be the source of the problem?
No, the problem is you use the wrong board config… jetson-xavier is for AGX Xavier.
Thanks! I didn’t notice it because I flashed xavier only via sdkmanager…
