Maybe other people want a rectangle light to be vertical, but every time I place one I have to rotate it 270 to make it flat to the horizon (like a ceiling light).
A default position choice would be nice if you don’t think it should always be flat like a plane like I do.
Also, it seems your default startup position is 45 degrees off. When you start the app and place a new plane on the screen, my view is always 45 degrees rotated.
The plane isn’t rotated, the Perspective’s camera view looks like this:
Steps to reproduce:
- Create a new project
- Add a plane.
This is what the ViewPort looks like.
I would expect it to look like this when added:
This will save having to position the new plane into view every time.
