Hello, I have a jetson agx orin and I want to downgrade to version 16 server. I tried to do it by mounting the ISO on a USB and an SD card but I was unsuccessful. I think I should change the UEFI settings, but I don’t know what settings to change.
You only get Ubuntu 20.04 with JetPack 5 and Ubuntu 22.04 with JetPack 6 on Orin series.
Other Ubuntu versions are not supported.
I think mostly you are trying with the x86 image, which of course does not work because you need ARM.
Even with an ARM image, it will still fail without customized stuff from NVIDIA.
There is some distribution of ubuntu 22.04 server compatible with the orin?
I’ve answered it here.
