LogDLSSBlueprint: Loaded DLSS-SR plugin version 3.7.2
LogDLSSNGXVulkanRHIPreInit: FNGXVulkanRHIPreInitModule::StartupModule Enter
LogDLSSNGXVulkanRHIPreInit: GetSelectedDynamicRHIModuleName = D3D12RHI
LogDLSSNGXVulkanRHIPreInit: VulkanRHI is not the active DynamicRHI; skipping of pregistering the required NGX DLSS Vulkan device and instance extensions via the VulkanRHIBridge
LogDLSSNGXVulkanRHIPreInit: FNGXVulkanRHIPreInitModule::StartupModule Leave
LogDLSS: FDLSSModule::StartupModule Enter
LogDLSS: PluginBaseDir …/…/…/Engine/Plugins/Marketplace/Nvidia/DLSS
LogDLSS: NGXBinariesDir …/…/…/Engine/Plugins/Marketplace/Nvidia/DLSS/Binaries/ThirdParty/Win64/
LogDLSS: GDynamicRHIName NVIDIA D3D12
LogDLSS: Plugin settings: NGXAppId = 0
LogDLSS: NGX Application ID not specified, using the Project ID by default.
LogDLSSNGXRHI: FNGXRHIModule::StartupModule Enter
LogDLSSNGXRHI: FNGXRHIModule::StartupModule Leave
LogDLSSNGXRHI: Searching for custom and generic DLSS binaries
LogDLSSNGXRHI: NVIDIA NGX DLSS binary nvngx_dlss.dll not found in search path H:\LyraStarterGame54Blank\Binaries\ThirdParty\NVIDIA\NGX\Win64
LogDLSSNGXRHI: NVIDIA NGX DLSS binary nvngx_dlss.dll not found in search path C:\Program Files\UE_5.4\Engine\Binaries\Win64\Binaries\ThirdParty\NVIDIA\NGX\Win64
LogDLSSNGXRHI: NVIDIA NGX DLSS binary nvngx_dlss.dll found in search path C:\Program Files\UE_5.4\Engine\Plugins\Marketplace\Nvidia\DLSS\Binaries\ThirdParty\Win64
LogDLSSNGXRHI: DLSS model OTA update enabled
LogDLSSNGX: [SDK]: [2024-07-11 18:59:17] [NGXSafeInitializeLog:141] App logging hooks successfully initialized
LogDLSSNGX: [SDK]: [2024-07-11 18:59:17] [NGXLoadLibrary:269] error: failed to load NGXCore: 126 (C:\Program Files\UE_5.4\Engine\Binaries\Win64_nvngx.dll)
LogDLSSNGX: [SDK]: [2024-07-11 18:59:17] [NGXLoadLibrary:269] error: failed to load NGXCore: 126 (C:\Program Files\UE_5.4\Engine\Binaries\Win64\nvngx.dll)
LogDLSSNGX: [SDK]: [2024-07-11 18:59:17] [NGXGetPathUsingQAI:138] Path to driverStore found using QAI: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5714f0dca6485379
LogDLSSNGX: [Core]: [2024-07-11 18:59:17] [NGXSafeInitializeLog:133] App logging hooks successfully initialized
LogDLSSNGX: [DLSS]: [2024-07-11 18:59:17] [tid:16328][NGXInitLog:219] App logging hooks successfully initialized
LogDLSSNGX: [DLSS]: [2024-07-11 18:59:17] [tid:16328][NGXInitLog:226] Built with APP_NAME = custom_engine_generic
LogDLSSNGXD3D12RHI: NVSDK_NGX_D3D12_Init_with_ProjectID(ProjectID = 5AF851D7468594B33E12E8AC66809885, EngineVersion=5.4, APIVersion = 0x15, Device=000002B535619D50) → (1 NVSDK_NGX_Result_Success)
LogDLSSNGXD3D12RHI: NVSDK_NGX_D3D12_Init (Log H:/LyraStarterGame54Blank/Saved/Logs/NGX/NGX_2024.07.11-18.59.17_C52F1AA64F53AD005265DBA1108CCBCE) → (1 NVSDK_NGX_Result_Success)
LogDLSSNGXD3D12RHI: NVSDK_NGX_D3D12_GetCapabilityParameters → (1 NVSDK_NGX_Result_Success)
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSampling_NeedsUpdatedDriver → (1 NVSDK_NGX_Result_Success), bNeedsUpdatedDriver = 0
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSampling_MinDriverVersionMajor → (1 NVSDK_NGX_Result_Success), MinDriverVersionMajor = 445
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSampling_MinDriverVersionMinor → (1 NVSDK_NGX_Result_Success), MinDriverVersionMinor = 0
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSamplingDenoising_NeedsUpdatedDriver → (1 NVSDK_NGX_Result_Success), bNeedsUpdatedDriver = 0
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSamplingDenoising_MinDriverVersionMajor → (1 NVSDK_NGX_Result_Success), MinDriverVersionMajor = 0
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSamplingDenoising_MinDriverVersionMinor → (1 NVSDK_NGX_Result_Success), MinDriverVersionMinor = 0
LogDLSSNGXRHI: NVIDIA NGX DLSS is supported by the currently installed driver. Minimum driver version was reported as: 445.0
LogDLSSNGXRHI: NVIDIA NGX DLSS-RR is supported by the currently installed driver. Minimum driver version was reported as: 0.0
LogDLSSNGXRHI: Get NVSDK_NGX_EParameter_SuperSampling_Available → (1 NVSDK_NGX_Result_Success), DlssAvailable = 1
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSamplingDenoising_Available → (3134193680 NVSDK_NGX_Result_FAIL_UnsupportedParameter), DlssRRAvailable = 0
LogDLSSNGXRHI: Get NVSDK_NGX_Parameter_SuperSamplingDenoising_FeatureInitResult → (3134193680 NVSDK_NGX_Result_FAIL_UnsupportedParameter), NVSDK_NGX_Parameter_SuperSamplingDenoising_FeatureInitResult = (3134193664 NVSDK_NGX_Result_Fail)
LogDLSSNGXRHI: NGX_DLSS_GET_OPTIMAL_SETTINGS → (1 NVSDK_NGX_Result_Success)
LogDLSS: QualityMode -2: bSupported = 1, ResolutionFraction = 0.3330. MinResolutionFraction=0.3330, MaxResolutionFraction 0.3330
LogDLSS: QualityMode -1: bSupported = 1, ResolutionFraction = 0.5000. MinResolutionFraction=0.5000, MaxResolutionFraction 1.0000
LogDLSS: QualityMode 0: bSupported = 1, ResolutionFraction = 0.5800. MinResolutionFraction=0.5000, MaxResolutionFraction 1.0000
LogDLSS: QualityMode 1: bSupported = 1, ResolutionFraction = 0.6670. MinResolutionFraction=0.5000, MaxResolutionFraction 1.0000
LogDLSS: QualityMode 2: bSupported = 0, ResolutionFraction = 0.0000. MinResolutionFraction=0.0000, MaxResolutionFraction 0.0000
LogDLSS: QualityMode 3: bSupported = 1, ResolutionFraction = 1.0000. MinResolutionFraction=0.9900, MaxResolutionFraction 1.0000
LogDLSS: NumRuntimeQualityModes=5, MinDynamicResolutionFraction=0.5000, MaxDynamicResolutionFraction=1.0000
LogDLSS: NVIDIA NGX DLSS supported 1
LogDLSS: FDLSSDenoiserWrapper(Active) wrapping ScreenSpaceDenoiser
LogDLSS: FDLSSModule::StartupModule Leave
LogDLSSEditor: FDLSSEditorModule::StartupModule Enter
LogDLSSEditor: DLSS module 00000B62EF3AB100, QueryDLSSSupport = 0 DLSSUpscaler = 00000B634A392940
LogDLSSEditor: FDLSSEditorModule::StartupModule Leave
