Attempting to use an extension to run a docker workflow from omniverse. However, the embedded version of python that omni kit comes with doesn’t work with the python script written to run the extension. I have attempted to change the ‘pythonHome’ and ‘pythonPath’ variables (in the kit-core.json file) to point to another version of python on my system (as shown in the guide: https://docs.omniverse.nvidia.com/py/kit/docs/guide/python.html). This, however breaks create and now it will crash on launch. I have also attempted to point the variables to a conda env which worked for the original developer of the extension but has now broken for his too.
Thanks,
Will
Hi @william.smith-14! Welcome to the forums! Could you provide some more information?
- What Python version are you using?
- What OS are you running?
- Can you provide logs from the crash?
Here’s more info about where logs are located: How to Report an issue with Omniverse
Hi, thanks for the quick reply,
- I was using the latest python version 3.9 but also tried again with 3.6 (as I believe that that is the version kit uses but still didn’t work)
- Windows 10
- I have attached the latest kit log but it will only allow me to upload one file at a time - if there are any others you need, please let me know
kit_20220622_112714.log (1.1 MB)
Also running an Laptop RTX 3080
Hi @william.smith-14. You can use a different Python interpreter than the one embedded with Kit, but it’ll still need to be at minimum the same major.minor version. (e.g. 3.7)
