ChatRTX v0.5 installer fails silently – no EXE installed, no logs generated
System Information:
  • GPU: NVIDIA RTX 3060 12GB
  • Driver: 552.xx (latest Game Ready driver)
  • CUDA Toolkit: 12.4
  • OS: Windows 11 Pro (Swedish language)
  • Admin Rights: Yes
  • Python: 3.11 installed
  • Visual C++ Redistributable: 2015–2022 (latest)
  • .NET Runtime: 6 and 8 installed
  • Antivirus: Windows Defender (temporarily disabled during install)
Issue:
When attempting to install ChatRTX v0.5 (installer downloaded from NVIDIA’s official site), the installer proceeds through:
✔️ System Check
✔️ License Agreement
✔️ Options
…but fails at the Install step with the following message:
❌ NVIDIA Installer failed
An unknown error has occurred.
Observations:
  • No error log is generated (%TEMP%, AppData, Program Files, etc. checked)
  • No executables like ChatRTX.exe or model-server.exe are installed
  • Only a few assets like .ico and .pdf files appear in installation directory
  • No GGUF model is downloaded (model downloaded manually to Documents\ChatRTX\models without success)
  • Running the installer with /log does not produce output
  • Running installer from CLI or as administrator makes no difference
What I’ve Tried:
  • Verified hardware and software compatibility
  • Installed all dependencies manually (Python, CUDA, Visual Studio, etc.)
  • Disabled antivirus and UAC
  • Tried running installer with admin rights and logging
  • Tried placing Mistral-7B-Instruct GGUF manually in models directory
Expected:
The installer should either:
  1. Proceed and install ChatRTX properly, or
  2. At minimum, provide a meaningful error log
Request:
Please advise on:
  • How to enable verbose logging or debug mode
  • Whether a portable/manual version of ChatRTX is available
  • If there’s an earlier stable version (e.g., 0.4) available for download
Thank you!
I guess: ChatRTX Installation Failed
Summary of the Situation:
  • I have an RTX 3060 12GB GPU (fully compatible with ChatRTX).
  • HTTPS and certificate validation on my system works perfectly fine:
    • I tested using both Invoke-WebRequest in PowerShell and curl from the command line to NVIDIA’s website and other relevant URLs — all returned HTTP 200 responses with no TLS or certificate errors.
    • My network has no VPN or proxy interfering with connections.
  • I have installed the latest NVIDIA drivers (version 555.xx or newer).
  • I’m running Windows 11 Pro 64-bit (fully updated via Windows Update).
  • However, the ChatRTX 0.5 installer still fails with the error code 0x80092012, which corresponds to:
CRYPT_E_REVOCATION_OFFLINE
“The revocation function was unable to check revocation because the revocation server was offline.”
Steps Already Tested (Still Failing):
  1. Installed latest Visual C++ Redistributable (vc_redist.x64.exe).
  2. Ran full Windows Update (including optional updates).
  3. Verified I can access https://nvidia.com and related domains via PowerShell and curl with no TLS errors.
  4. Disabled Windows “Check for publisher’s certificate revocation” and “Check for server certificate revocation” in Internet Options (no difference).
  5. Cleared Windows certificate cache using:
bash
certutil -urlcache * delete
  1. Ran the installer as administrator and in compatibility mode — still fails.
Possible Root Cause:
It seems like the installer itself is:
  • Making curl/HTTPS requests internally during installation.
  • Unable to validate certificates during those internal requests, despite the OS itself working fine.
  • Not handling this error gracefully and simply failing the entire installation.
Additional Context:
  • Some users on the NVIDIA forums report similar failures and have worked around this by:
    • Using a different Windows user account (sometimes works).
    • Manually copying the installed ChatRTX folder from another machine where installation succeeded.
    • Waiting for NVIDIA to release a patched installer.
Request:
Could you please review the ChatRTX 0.5 installer’s handling of certificate revocation checks, especially around the 0x80092012 error? It looks like the installer fails to properly handle scenarios where CRL/OCSP checks cannot complete, even though the OS itself has no such issues.
can you please uninstall ChatRTX and try installation with below steps and share logs with us ?
Generating Installation Failure Logs
By default, installer logs are automatically created in the %temp%/NvidiaLogging directory. However, these logs are temporary and are deleted when the installer process exits.
To create persistent logs that can be used for troubleshooting, you can use command line options with the installer executable.
To do this:
Run the installer executable with the following command line options:
<installer_exe_filename> -log:<log_directory> -loglevel:6
For example: setup.exe -log:c:\logs -loglevel:6
This will generate detailed logs in the specified directory.
Important: To help us investigate installation failures, please share the entire logging directory with us. This will enable us to diagnose and resolve the issue more efficiently
For myself, I solved this by installing 0.3 first, and then on top of it, 0.5
