Checking power information when using jetson nano
Hello, I am using Jetson nano and I want to check the battery capacity when I using it. I think this task needs support from the hardware and Nvidia may provide some API to do that. So can I check this parameter? and how to check it?
Many thanks. :D
Hi hieu.phamnt39,
May I know what battery and interfaces are you using? The nano shipped out does not have battery but only AC and usb as power supply.
Hi WayneWWW, I am using a backup charger as a power supply (5V-2.5A, type which often use for cellphone), power was supplied through 5V-2A port (micro USB).
Hi hieu.phamnt39,
No, no such interface is supported for usb power bank. Do you have any platform that is able to read the power status of a usb power bank?
Hmm, I don’t have. But can I know some types of power supply (battery) which is supported by Jetson nano to read power status?
No such battery for nano. You can read the value of VDD_IN to module thru power monitor in the module. There are detail info in doc: https://developer.nvidia.com/embedded/dlc/jetson-tx1-tx2-voltage-current-config
