So I have followed the directions of previous posts to change to flash_l4t_external and re-run SDK manager for 5.1.2. I see the APP partition is created to 14GB. I still run out of space on the 1TB NVME drive loading the APIs.
Is using SDK manager for the NX with 5.1.2 the wrong way to go?
I can’t find where the APP partition size value gets set to change it.
I’ve seen the command line to run the flashing to the NVME drive, does that do something different than SDK manager?
Sorry this is a repeat but I’ve read and tried all the other psots with the same answer for the switching the .xml file and using the command line.
Still having the issue. I must be missing the final post to this issue with my searches. Can you please point me to it?
