I have a question regarding the behavior of joint drives in Omniverse when using the Max Force parameter.
According to the documentation, the joint force is calculated by:
𝐹 = stiffness × (x_target − x) + damping × (v_target − v
My question is: If this calculated force exceeds the set Max Force, does Omniverse proportionally scale down the stiffness and damping terms by the ratio ? Or does it simply clamp the resulting force to the Max Force without adjusting stiffness and damping?
Any clarification on this behavior would be greatly appreciated.
