Client unable to connect to the streaming via Azure Load Balancer
I’ve deployed OVAS on Azure. I start local client (usd-viewer-streaming-sample) to connect the streaming, but I got the error as follows:
WebSocket connection to ‘ws://51.8.36.40:31000/sign_in?peer_id=peer-7852470860&version=2’ failed: WebSocket is closed before the connection is established.
streaming pod logs:
AKS services:
Daniel,
What is the output of:
kubectl get pods -n omni-streaming
I want to see that the kit-app-XXXX pod is successfully loaded.
Also, what is the output of:
kubectl get ingress -n omni-streaming
Are you using an API gateway in between your web client and your Azure cluster?
Are you still having issues with this?
