So I follow it to push file to /sdcard directory and success, but seem the launch options file still not work, it didn’t seup my server ip address. Where should I put the CloudXRLaunchOptions.txt file?
This problem is solved and the launch option file should be push into your client apt install directory. For my case, I check my CloudXR apt file in Quest 3 was located in /sdcard/Android/data/com.nvidia.cloudxr.test , therefore, I just put my option file to /sdcard/Android/data/com.nvidia.cloudxr.test/files/ directory, then it works.
