Hi.
Trying to use CloudXR on my Quest 2.
Could sideload the demo app APK and have the server running on my VR PC.
Creatded the CloudXRLaunchOptions.txt with the -s 192.168.1.23
There is no sdcard slot that I know of on the Quest 2
Uploaded it via AndroidFileTransfer in /Android/obb/com.nvidia.cloudxr.ovr
Uploaded it via AndroidFileTransfer in /Android/data/com.nvidia.cloudxr.ovr
Uploaded it via AndroidFileTransfer in a folder /sdcard/
Launch SteamVR, launch the Quest client, and… nothing.
What did I do wrong ?
Perhaps a dumb question but is 192.168.1.23 the computers local IP, and are they connected to the same network?
Not dumb, always check
And yes, it’s the server IP.
And yes, I tried with a regular CloudXR client (Win 10 openVR).
It really is a question of how to set the server address.
/sdcard is where you’re meant to put it (while there’s no SD Card on the Quest, that’s basically the data folder for the Quest)
adb push CloudXRLaunchOptions.txt /sdcard/CloudXRLaunchOptions.txt
If it still doesn’t connect I would suggest watching adb logcat
This is what I did using Android File Tranfer on my Mac
Something must be wrong, but what ?
File format, file authorisations, end-of-line ?
Any idea ?
I have to install Android tools to use ADB
Will update the thread when done.
Installed Android Studio, running ADB
it pushes the file into the root folder as if If pushed to /CloudXRLaunchOptions.txt
(as I can see via Android File Transfer)
Even making a sdcard folder does not help.
For people ending here is search for a solution. It’s sooooo simple. The root folder on the Quest is actually the /sdcard folder. Just push the TXT file in the root folder of the Quest and you are done.
