Is it, or will it be possible to specify value of Ant Build → Native Library Dependencies / Native Library Directories when generating NSight Tegra project from CMake? Because .so files on which the project depends, are not copied inside APK otherwise. I think there may even be no need to specify this value manually, but just add all .so files from Linker → Input → Additional Dependencies here.
It is not yet possible, but we’re planning on adding a much more mature Nsight Tegra support to CMake in the foreseeable future. Your case will be taken into account for developing the feature list. Thanks for the feedback!
Thank you, I will be waiting for the new version.
The support for Native Library Dependencies / Native Library Directories (among other things) has been added to CMake some time ago: VS: Add more Nsight Tegra generator Android property settings (8c0afaf4) · Commits · CMake / CMake · GitLab
This feature should be a part of the next CMake release.
