Collision from Isaac Sim Running with Moveit Trajectory
Isaac Sim Version
o 5.0.0
Operating System
o Ubuntu 22.04
GPU Information
  • Model: RTX 2060
  • Driver Version:
Topic Description
Detailed Description
Trajectory Execution : I generated trajectory using Moveit2, and executing in Isaac Sim by publishing to joint_commandswith10Hz. Isaac Sim physics_dt is set to 30Hz.
Collision Object Generation : Object is generated from Isaac Sim and publish pose information to Moveit2 planning_scene. ← Assuming this part could go wrong because of meshes, but unsure to fix it.
Bug : Trajectory generated from Moveit2 making a slight collision between robot and collision object.
Screenshots or Videos
  1. Initial Position (No bug)
  1. End position (No bug)
  1. Collision between link6 & object (Bug)
What I’ve Tried
  1. Matching joint_commands publish rate to physics_dt of isaac Sim.
  2. Interpolating generated trajectory to have more waypoints.
  3. Set restOffset = 0 and contactOffset = 1e-5 to reduce collision detection distance. ← I thought this would solve the problem but it didn’t.
  4. Ran the trajectory without Isaac Sim –> No collision issue happened.
Issue still persists with above trials. I’m wondering if my setup could be wrong :
Isaac Sim publishes objects to Moveit2 planning_scene --> Send goal to Moveit --> Trajectory --> Publish to execute (10Hz)
Any suggestion will helpful. Thank you!
I think this is a problem of difference between ros_controller and Articulation Controller. I just fixed this by add padding on the ROS’ collision object. Now it doesn’t collide, but not sure if this is the right fix. I honestly have no idea how to resolve this issue.
Hi, it looks like your request fell through the cracks here. Did you manage to resolve this issue, or is it still persisting?
Hi I could resolve the issue, and it was not Isaac Sim problem.
Great! Thanks for letting us know.
Closing this issue.
